Results 1 to 5 of 5
    ROG Member Array
    Jan 2012
    7
    [Help] Booting from cd with Asus g73jh
    Hello, when i enter bios i cant fint the option too boot from my windows 7 cd anyone know a tutorial?
    ROG Guru: Yellow Belt Array VistaKing's Avatar
    Dec 2011
    Location
    CALIFORNIA
    14
    130
    Try pressing ESC when the ASUS splash screen comes up and you should get a menu with options that you would be able to boot off from.
    Created by DaemonCantor and Adam
    ROG Member Array
    Jan 2012
    7
    Quote Originally Posted by VistaKing View Post
    Thanks but shouldent i change so it always boot from cd when im reinstalling Windows?
    Dec 2011
    Location
    CALIFORNIA
    14
    130
    Not really. You could use the ESC key to pop up a boot menu and choose ODD or USB which ever you have windows . Windows 7 takes 45 mins to do a clean install from a DVD . While in a USB FLASH DRIVE it takes 15 mins from start to finish .
    ROG Guru: Black Belt Array
    Oct 2011
    Location
    USA
    31
    2,916
    Nope.....no need to access or change the BIOS. Windows Setup loads all the files it needs from the CD during the first phase of installation....it doesn't access the CD again after that. So just using the Boot Menu for that first boot from the CD is all you need.
