It's about 4 months old. I am wondering if this is something I can repair/replace, or if I have RMA it.
Could be a bad bearing in the fan. How comfortable are you disassembling/assembling laptops? Ever done it before?
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
You may also find that something is contacting the fan, creating the noise. See http://forum.notebookreview.com/asus...ns-photos.html
You can probably get the part number from contacting ASUS. What you have to decide is - do I want to void the ASUS warranty by attempting this repair?
I found a video for disassembly to add ram and 2nd hard drive, and I have the unit disassembled this far, but it looks like further disassembly will be a bit more complicated. Is there a good video on full disassembly? Ideally I want not to break something AND void warranty AND not fix fan.
Did you see http://www.youtube.com/watch?v=TdQi2GMQRu8?
yeah, that's OK but the angle is terrible, mostly you see the side of the case and his arm. FWIW this is what my fan sounds like
http://www.youtube.com/watch?v=KUntoP31UdY
any ideas whether this the bearings or something rubbing? The latter seems unlikely because I haven't moved the machine in weeks.
