+ Reply to Thread
Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 59
Thread: Help with extremely unstable Rampage IV Extreme/BF edition
  1. #11
    Super Moderator Shamino +10
    Jul 2011
    Location
    tw
    456
    how about mode 2 then?
  2. #12
    ROG Guru: Blue Belt 8 Pack +20 8 Pack's Avatar
    Nov 2011
    Location
    U.K
    884
    Hivizman means VCCSA yes. What he is suggesting is that you should not need more than 1.15v on VCCSA to get your system stable with the DIMMS current XMP speed, At a guess this will be 1600mhz??? While your at it I would try VTT at 1.15v also and The RAM voltage at 1.575v. This should stabalise your system.
    Have you got both EZ plugs in the board as these give the dimms more power when using 8 sticks.
    Intel 3930K 5.5ghz+, DDR2600 , 3570K ,3770K
    ASUS RIVE, MVG,MVF,MVE.MIVE,MIVG -EZ
    G.Skill RipjawZ,PI and Trident X
    ASUS 7970, GTX580,570,470,460 etc etc
    Antec HCP 1200w x 2 and Coolermaster 1200w
    http://www.hwbot.org/user/8_pack/
    The GB Bencher. http://www.team-greatbritain.com/team-gb-members/
    Proud to be an ASUS power user!!!
  3. #13
    ROG Enthusiast jimdigriz +10
    Feb 2012
    32
    Quote Originally Posted by 8 Pack View Post
    Yes, XMP on the Corsair Vengeance means 1600MHz. I will try those settings. Thanks for the advice, much appreciated!
    I have only the 4-pin one attached as the manual says that's the one providing power to DIMMs. I didn't bother with the 6-pin one since that's for additional power for four PCIe3.0 display cards, again according to the manual.
  4. #14
    Nov 2011
    Location
    U.K
    884
    Yeah thats fine then power wise. Try the settings I suggest next.
  5. #15
    Feb 2012
    32
    Hmm. Is it normal (heh) that the PC freezes/crashes while in the BIOS settings screen? That's happened to me twice now.
  6. #16
    Feb 2012
    32
    OK, this is not good. I tested with following settings:
    Optimized Defaults +
    XMP & Mode 1
    CPU VCCSA 1.100
    DRAM Voltages 1.575
    VTTDDR Voltages AUTO
    VTT CPU Voltage AUTO (~1.26)
    2nd VTT CPU Voltage AUTO (~1.050)
    Booted to Windows, started my usual x264 encoding test... and in less than 1 minute the PC rebooted without warning. No BSOD, no error messages, nothing.
  7. #17
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    12,757
    That is odd.
    Can you do something for me.
    Use two sticks in dual channel and see if the system is stable. If yes at two more sticks and run stability test. Your encoding thing. Again if passes then add two more.
    Use the settings that 8ball has suggested when you do this little test.
    As to having freezes in BIOS well yes. But that was at -170'c so not quite the same situation.
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
  8. #18
    Nov 2011
    Location
    U.K
    884
    Not normal no but if its unstable its possible.
  9. #19
    Nov 2011
    Location
    U.K
    884
    Vccsa 1.2???
  10. #20
    Feb 2012
    32
    Quote Originally Posted by HiVizMan View Post
    I was dreading this suggestion would come up. Cooler fans wouldn't allow the removal of the closest two sticks so I had to yank the fans. It's also why I had to buy low profile DIMMs, so they'd fit under the fans.
    Anyhoo, the rig is now up and running on two sticks. I'll update this post when something happens.
+ Reply to Thread
