+ Reply to Thread
Results 1 to 3 of 3
Thread: M4A89GTD PRO/USB3 IGPU
    New ROGer Scott +10
    Dec 2010
    2
    I'm trying to setup a third monitor on my computer right now, connecting it to my igpu, 4290, and can't seem to get it to work. I've enabled SurroundView in the BIOS and the Primary Video Controller setting is PCI-GFX0-GFF-IGFX. My primary video card is a 4850 and has two monitors hooked up to it. I'm just wondering if I've missed something to enable the onboard gpu or what it is that I'm doing wrong as the catalyst control center is telling me the 4290 is disabled.
    Any help would be greatly appreciated.
    New ROGer Scott +10
    Dec 2010
    2
    Fixed the problem, the HDMI cable that came with the TV was bad. Hope this helps anyone else that comes across this problem.
    ROG Guru: Blue Belt martin_metal_88 +10 martin_metal_88's Avatar
    Apr 2010
    Location
    Quebec
    812
    Glad to see that you fixed the issue even before we answer XD Hope you will stay around here and keep posting Welcome on Asus rog forum!!
    Martin_metal_88
    Colenzo :Coolermaster ATCS 840 | Gigabyte's EP55-UD5 | Intel Core I7 860 @ 3.8Ghz | 4GB G.skill Trident 1600 | MSI GTX460 1GB HAWK Twin frozr | WD 640 black + WD 1TB green + WD 1TB Blue | Pionner DVR-216 | Silverstone Strider Plus 850W | Coolermaster Hyper 212 plus in push pull fan config |
    Ask for more!
+ Reply to Thread
Similar Threads
  1. M4A89GTD PRO PCI-E Boot Support ?
    By bkarankar in forum NON-ROG AMD Motherboards
    Last Post: 07-13-2011, 01:58 AM
