My ASUS wont start when i press power button
tegnebok
i updated my bios 202 to 203 because of the 2d/3d ROG button. and when i updated with EasyFlash it finished and it was gonna to restart, after the restart it wont start! no signs of lights or fans. nothing happens when i push the power on button.
please help i just got the computer 4 days ago and expensive :(:(:(
i got the Asus G74sx-91287V
24 REPLIES 24
fuzon1337
Hi
This issue sounds like it's bricked after you flashed your BIOS.
You can try to take out the battery leave it out and push the power on button for 30 sec and then reconnect it and see if that helps.
If not, you have to RMA the situation.
Asus G73SW-91058V 3D
- Intel Centrino Ultimate-N 6300
- BIOS 205
it didnt work to take out the battery for 30secs. or i just did it wrong. i dont know what RMA means 😞
fuzon1337
Are you from Norway ?
That means you have to call Asus Hotline and tell them that you're notebook won't turn on and what you should do. They might give you some advise, and if the advise doesn't work, they start a case and you can send the notebook in to rep.
- BIOS 205
yes, im from Norway and thank you i'll contact them
fuzon1337
Okey 😉
Here is a link to the phone support.
(Norway 00 47 23 16 26 82 09:00-17:00 Mon. ~ Fri.)
I have good experience with InfoCare (where your notebook will be sent to after you have RMA it)
(when I sent my notebook there last time, it took one week before I had it back 🙂 )
EDIT: Nothing happends when you try to push the power button ?
- BIOS 205
ok... RMA is something i do? i though i was a... i dont know what RMA is and what it stands for....
fuzon1337
RMA stands for Return Merchandise Authorization, and this RMA situation is a number that you start so the repair center know what to do when they get your notebook 😉
If I'm not wrong the warranty covers a bad bios flash also.
So to answer your question, yes, this is something you have to do or else you have a pretty pricey paper weight on your desk =/
- BIOS 205
lol morsomt og takk:p
fuzon1337
No problem 😉
- BIOS 205
