Results 1 to 7 of 7
    ROG Member Array
    Oct 2011
    Location
    Arad
    14
    Question How to save bios settings and load settings after bios update ?
    Hi guys.
    This is my second thread about Crosshair V Forumula. I must say that I'm very pleased with it.
    So, my current version of BIOS is 0903 (updated from stock 0813).
    I have in plan updating the BIOS to 1102 version.
    Before doing that i want to know if:
    1. my current bios settings can be saved to a file ?
    2. after updating bios it is possible to load the saved bios settings file to the new bios version ?
    Which are the steps to do that ?
    Hope for an answer and help.
    Thanks.
    kr!s
    Dec 2011
    Location
    London
    256
    25,205
    1. No
    2. No
    That was simple.
    When you flash bios you can not save the settings because the settings are specific to a particular bios. And for that reason you can not transfer the settings. 9/10 times most people do not make extreme changes, but a BIOS will often determine how ram works. So a setting configuration that worked with one BIOS might be unstable with another.
    Hope that answers your question.
    Shut Up Stupid! Array DaemonCantor's Avatar
    Jun 2011
    Location
    Ohio, USA....
    175
    2,289
    WoW! that was a quick answer!
    Dec 2011
    Location
    London
    256
    25,205
    Quote Originally Posted by DaemonCantor View Post
    Not really OP was made 16 before I replied.
    ROG Member Array
    Oct 2011
    Location
    Arad
    14
    thank your for your reply. so, i'll have to browse all my bios for settings and write them down on a paper.
    my settings are related to lan stability. remember those BSOD because of bad intel driver ?
    back then I found a topic about some specific settings that makes LAN stable and not cause the BSOD,
    but i can't find that topic anymore and i don't remember the changes.
    anyway, thanks for reply.
    kr!s
    Dec 2011
    Location
    London
    256
    25,205
    Kris just take screenshots of your current bios mate. F12 onto a fat formatted USB drive
  7. #7
    ROG Member Array
    Oct 2011
    Location
    Arad
    14
    ok. good to know that. i'll return with new info after update.
    thanks again.
Tags for this Thread
