Results 1 to 2 of 2
    ROG Enthusiast Array
    Nov 2010
    43
    Asus G73JH RBBX05 Wireless has stopped working....
    Yes my router has wireless yes it works on other laptops and YES i have restarted the router and my computer!
    This happend just less than a month of buying it!!....
    ROG Enthusiast Array XZEMi's Avatar
    Dec 2010
    Location
    Dallas
    56
    I dont own one of these but i'd like to lol. One thing I can suggest is uninstall any bluetooth and wireless drivers from the system and reinstall updated versions. Also some laptops have touch sensitive buttons to enable or disable bluetooth or wifi so try cycling those or make absolutely sure none of those are switch off by accident. Also if no touch sensitive buttons many have the FN key (function key) option to disable bluetooth or wireless from the keyboard. Ensure none of the above has been disabled and do the driver updates, if still no dice then I would return or find a new wireless card for mini pcie. There is a slight chance the mini pcie card is not seated well or has gone bad also.
Similar Threads
  1. G73JH control deck and wireless console3 problems
    By ATi in forum G Series Gaming Notebooks
    Last Post: 12-19-2010, 09:01 AM
  2. ROG Mouse stopped working
    By dair in forum G Series Gaming Notebooks
    Last Post: 12-17-2010, 05:51 PM
  3. ASUS G73JH RBBX05 error 15 minutes after getting it.... I am furious
    By Mark Dano in forum G Series Gaming Notebooks
    Last Post: 12-12-2010, 02:32 AM
  4. ASUS Working on MARS II Dual GTX 480 Graphics Accelerator
    By ottoyu34 in forum Overclocking & Tweaking
    Last Post: 12-07-2010, 03:14 AM
  5. Replies: 15
    Last Post: 11-30-2010, 12:18 AM
