+ Reply to Thread
Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 45 of 45
Thread: HD 7970 and 120Hz problems
  1. #41
    ROG Guru: Orange Belt LiveOrDie +10
    Dec 2011
    389
    Well DVI and HDMI are cross compatible both have the same amount of pins, But DP isn't cross compatible you need an adapter and even then it wont support 120hz, If your TV supports HDMI 1.4a 3D 120hz you should be able to use a HDMI cable, I dont have a TV that can do 120hz so i cant tell you if the card can do more than 60Hz though the HDMI port, another option is to buy a DVI-D to HDMI cable which should support 120hz but you will get the glitching which i think is related to drivers because all 7950 and 7970 has this problem no mater the brand, Not sure why the DP doesnt have the same problem maybe because DP has head room when DVI-D is maxed out.
    Intel Core i7 3930K @ 4.25Ghz
    Corsair H100i + 2x Cooler Master Excalibur PWM Fans
    ASUS Rampage IV Extreme
    EVGA GTX 680 IN SLI + EVGA GTX 650 SC PhsyX
    ASUS ROG Xonar Phoebus
    Corsair T600
    G.Skill Ripjaws Z F3-17000CL9Q-16GBZH (4x4GB) DDR3
    2x Samsung 840 pro 256 in RAID0
    2x WD VelociRaptor WD3000HLFS in RAID0
    Cooler Master 1000W Silent Pro GOLD
    Samsung S27B970 27" Wide PLS Monitor - 2560 x 1440
  2. #42
    ROG Guru: Yellow Belt VistaKing +10 VistaKing's Avatar
    Dec 2011
    Location
    CALIFORNIA
    130
    I don't think my TV has HDMI 1.4a . My TV is an 09 model Samsung LN46B550K1FUZA
    Created by DaemonCantor and Adam
  3. #43
    Dec 2011
    389
    Is it this model ? http://www.ccereviews.com/reviews/sa...inch-lcd-tv/3/ because if you look at the specs you will find this
    LCD 120Hz NO (60Hz)
    Corsair T600
  4. #44
    Dec 2011
    Location
    CALIFORNIA
    130
    That's not my model. I don't think it will matter to me cause I don't play PC games . So I will be ok with 60hz
  5. #45
    Dec 2011
    389
    Even with using DP im getting random glitches and signal drop outs were ill have to turn my screen off and back on.
    Corsair T600
+ Reply to Thread
