+ Reply to Thread
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 73
Thread: Oc of a 270k help plz
    ROG Enthusiast Shamanji +10
    Feb 2012
    45
    this is my pc spec's...
    Asus Maximus Extreme-z [Bios 1004]
    Intel I7 2700k 3,5 Ghz [Kψlet af Arctic Cooling Freezer XTREME Rev. 2]
    16 Gb Ddr 3 Ram
    2 Stk Xfx 6990 4gb
    Silverstone St 1500W Psu
    2x WD raptor 600gb [Raid 0]
    3x 1500 Gb [Lager]
    1 x Dvd nec Drζnder 16x
    when i try to oc my i7 2700k i disable the Speedstepping and tubo Boost mode in bios and turn cpu ratio up..but when i reach 40 = 4000Mhz Turbo Boost automaticly turns it self on again, and i cant disable it again...i dont know why, i tried reading other theads about it but no luck so far...can anyone help me here?
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    12,836
    Have you tried any of the over-clocking guides? I would really recommend this one.
    http://rog.asus.com/forum/showthread...U-Core-Voltage
    Have a read and try using that method. If you get stuck please feel free to post back here and I will gladly help you get your system over clocked.
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
    Feb 2012
    45
    i read, but the way i see it is that he overclocking with the turbo boost mode, and that is what im trying to awoid..i want a oc of the cpu without turbo boost mode. if it is written in that linked post i must have not seen or undestod it.
    Dec 2011
    Location
    London
    12,836
    OK
    Go into BIOS F5 and enter
    • Navigate to the AI Tweaker
    • Ai Overclocker Tuner - Manual
    • BCLK/PEG Frequency – 100
    • Turbo Ratio: By All Cores (Can Adjust in OS) – 44
    • Memory Frequency – Auto or 1333MHz (we will return to this later)
    • DRAM timing
    • Manually set the top 5 settings to the values you will find on your DDR3 ram modules.
    • They are CAS Latency, RAS to CAS Delay, RAS Pre Time, RAS Act Time and DRAM Command Mode
    • AI Tweaker – scroll down to the voltages
    • CPU Voltage – Manual
    • CPU Manual Voltage – Type in the value 1.22 or use the + symbol on your keyboard until you see the value 1.22 in the active pane.
    • DRAM Voltage – Set the voltage to the recommended voltage as specified on your DDR3 set of ram.
    Disable Speedstep in enhanced CPU settings.
    F10 and enter
    Done
    Feb 2012
    45
    Quote Originally Posted by HiVizMan View Post
    OK
    • DRAM timing
    F10 and enter
    Done
    ok ill try that later thanks.
    Feb 2012
    45
    hello again, i jsut looked into the bios for the setting i should change, there is some things i need to ask HiVizMan about.
    you wrote • Turbo Ratio: By All Cores (Can Adjust in OS) – 44.
    in my bios i can adjust 2 thing related to the • Turbo Ratio: By All Cores (Can Adjust in OS) – 44.
    1. Turbo Ratio = All cores [Adjustable in os]
    2. Maximum turbo ratio settings [Adjustable in os] = Auto
    those things are what loading optimized bios settings chose to set them too.
    what do i choose in those?
    the 2. Maximum turbo ratio settings [Adjustable in os] = Auto, do i set that too 44 like you wrote in • Turbo Ratio: By All Cores (Can Adjust in OS) – 44 ???
  7. #7
    Feb 2012
    45
    The thing you want me to do is oc with the turbo boost mode right?
    because that is what i dont wanna do, i want oc the cpu but not with the turbo boost mode enabled, i want oc with the turbo boost mode disabled.
  8. #8
    Dec 2011
    Location
    London
    12,836
    Hi again my friend.
    What I want you to do is set the values I posted. That is all you need to do. Just set those values.
    Where it says AUTO type in 44
  9. #9
    Feb 2012
    45
    and this will overclock with turbo boost being enabled?
  10. #10
    Dec 2011
    Location
    London
    12,836
    As per your request = No it will not.
+ Reply to Thread
