+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: G53 SX Power jack - LOOSE PART - Help, please!
  1. #11
    ROG Guru: Black Belt BrodyBoy +20
    Oct 2011
    Location
    USA
    2,916
    Quote Originally Posted by Phate18 View Post
    I don't have the necessary tools to do that, let alone the knowledge... In fact, I have no tools and no knowledge of electronics.
    I'm not worried about the data (it's all backed up externally, or at least the important stuff), it's the actual disks I'm worried about. They wouldn't take them or replace them, would they?
    No, they won't confiscate or replace them. But I think they do routinely perform a factory restore on the boot drive. Since this is just a hardware repair, and they're not messing with software, perhaps you could include a note asking them to not do that unless it's absolutely necessary.
  2. #12
    ROG Member Phate18 +10
    Sep 2011
    Location
    Czech Republic / United Kingdom
    15
    Update: The laptop came back from RMA in about 7 days, they replaced the motherboard and charging works fine now.
    However, the keyboard is no longer illuminated and the F3 and F4 keys don't work anymore (in regards to increasing/decreasing the luminosity of keyboard lighting). All other F-key functions seem to work. Any idea why this might have happened? Thanks!
  3. #13
    Oct 2011
    Location
    USA
    2,916
    Did they do a factory restore on your software installation?
    Try a repair installation of the ATK package.
  4. #14
    Sep 2011
    Location
    15
    No, the system is just the way it was when I sent it off, I included a note asking them not to wipe my drives unless completely necessary.
    Do you mean this http://dlcdnet.asus.com/pub/ASUS/nb/...64_Z100014.zip ?
  5. #15
    Oct 2011
    Location
    USA
    2,916
    Yes, that's the latest ATK Package that's usually recommended for the most recent G-series.
    If you are not using that one already, un-install the current ATK Package and reboot before you install the new one.
    If you already have v.1.0.0014 installed, you do a repair installation in Control Panel.
  6. #16
    Sep 2011
    Location
    15
    I installed v 14 and rebooted, but the issue persists. I also installed the KB filter driver recommended in the driver thread, but I don't think that has anything to do with keyboard backlighting.
    Any other possible cause?
  7. #17
    ROG Guru: Gold Belt dstrakele +75 dstrakele's Avatar
    Sep 2011
    Location
    USA
    4,357
    Does the keyboard illuminate briefly when you boot the system? It should flash. If it doesn't, try entering the BIOS (press F2 at the ASUS splash screen) then Load Optimized Defaults (F9) and Save & Exit.
    If that fails, unplug the notebook and remove the power adapter and battery and any attached peripherals (mouse, USB HDD, USB keyboard). Press the Power On button and hold for 30 seconds. Then attach the power adapter, plug in, and boot the system.
    If this fails, the power cable to the keyboard backlights may be disconnected, not connected properly, or is faulty. My guess is they forgot to connect the keyboard backlight cable after replacing your motherboard (or accidently damaged the cable connector when removing it).
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
  8. #18
    Sep 2011
    Location
    15
    No, I remember it doing that before the RMA. Now it doesn't.
  9. #19
    Sep 2011
    Location
    USA
    4,357
    Try the recommendations I added to my previous post. I think they have a low probability of success, but it's worth eliminating any possibilities before you disassemble the laptop or send it back in RMA.
    The backlights MUST flash briefly at bootup - even if they are disabled in Windows.
  10. #20
    Sep 2011
    Location
    15
    Okay, thanks! I'll give those a go.
    Although, if it was simply the case that there is no power coming to the lights, wouldn't the system still show the icon when I press the lighting bbuttons (F3 F4) ? Wouldn't it still try to regulate it, even though there'd of course be no change in the lights?
+ Reply to Thread
Tags for this Thread
