+ Reply to Thread
Results 1 to 2 of 2
Thread: Memory Issue on Maximus IV GENE-Z
    I'm using 2 x 4Gb Corsair Vengeance (CMZ8GX3M2A1600C9), they only seem to work in memory slots A1 and A2. If I try to use any other combination my computer POSTs code 58 resets once and POSTs code 58 again and goe no further.
    Today I bought another two memory modules as mentioned above and filled all four slots - but still get code 58 and the computer won't boot.. does anyone have any suggestions?
    Motherboard : Maximus IV GENE-Z
    CPU Type : i7-2600 LGA1155
    Operating System : Windows 7 64bit
    Requested technical assistance at vip.asus five days ago and still have no reply.
    Please help!
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    12,834
    Reseat your CPU.
    Dimm slots not working are often the result of unequal pressure on the CPU. Remove the CPU completely not just the cooler.
    Same time check for stuff in the Dimm slot that might be causing a problem.
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
+ Reply to Thread
