Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ROG Enthusiast Array
    Feb 2012
    Location
    Sweden
    42
    (SOLVED) System Unstable. Your CPU Ratio may be down at 12x due to unsuitable...
    This is sooo annoying, i've been getting this error since i set my old triple kit 12gb 2000mhz dominator gt's to 1866mhz & i'm still getting it even after buying a new quad 4x4gb 2133mhz dominator gt kit, everytime i set it to X.M.P. i get this annoying error (System Unstable. Your CPU Ratio may be down at 12x due to unsuitable conditions). Even when i set the new DIMMs to 1866mhz, i get that message now and then, it's really annoying me & i don't want to start regretting upgrading to a Rampage mb. Please tell me what to do in order to avoid the so called "instability" that the mb claims.
    PS. i even tried increasing DRAM voltages, CPU PLL Voltage & VTT voltage but nothing worked, even set the timing manually,even ran memtest for 1 hour 25 minutes ( http://img827.imageshack.us/img827/8849/memtestorg.jpg ) but i still get that message now and then (mostly after the following startup of a successful post). I have latest BIOS too (1101).
    UPDATE: Overclocked CPU because i was sure that i should either use OC'd ram along with OC'd cpu or just use both at very stock, so i just OC'd CPU to a stable 4.7GHz & DIMMs are now running at 2133MHz as well, all stable.
    Super Moderator Array
    Jul 2011
    Location
    tw
    30
    578
    set clockgen filter to 20UF
    Feb 2012
    Location
    Sweden
    42
    Quote Originally Posted by Shamino View Post
    ok will see.
    ROG Guru: White Belt Array
    Jan 2012
    20
    96
    I'm getting the same message with my new 2133 G.Skill ram, too.
    Antec 2002 Chassis - AMG 1000 Modified
    Asus Rampage IV Extreme (bios 4201)
    Intel® Management Engine (firmware 8.1.10.1286)
    EVGA GTX 680 - PCI-E @ x16 3.0 (driver 332.21)
    Intel 3960x revision C2 @ 4.7ghz daily - rock solid
    G.Skill Ripsaw Z - 32 gig @ 2133mhz
    Corsair: 2x Force GT, AX1200, H80
    Windows 7 64bit
    Feb 2012
    Location
    Sweden
    42
    Quote Originally Posted by Terminal Meltdown View Post
    Changed ClockGEN Filter to 20UF like Shamino said & i hope i won't get that message the next time i post.
    Jan 2012
    20
    96
    That worked, thanks. I'm only testing with 16gig at first, and then putting the rest in for 32gig later this weekend.
    Windows 7 64bit
  7. #7
    Feb 2012
    Location
    Sweden
    42
    simpler was
    Yup, booted for second time now after changing ClockGEN and no error this time.
  8. #8
    New ROGer Array
    Feb 2012
    1
    i have 32 g of mushkin 1600mh 7-8-7-24 (99400) and this fix isn't working for me. it even restarted and wouldn't even post, when i was trying to undo the settings after f1. i had to kill the power and clear cmos (i love that external button).
    i can't even use any of the easy overclocking features , but that's a different thread i suppose.
    please help. i just want my ram to work at the rate i paid for.
  9. #9
    Dec 2011
    Location
    Sweden
    39
    "System Unstable. Your CPU Ratio may be down at 12x due to unsuitable conditions !! "
    Change memory setting from auto to Mode 1 and Turbo Ration from Auto to "By All Cores".
    Intel 3930K @ 4.2ghz C1 @ Offset Auto @1.3V
    ASUS Rampage IV Extreme (BIOS-4901-BOLTS4BREKFAST Mod)
    16 gb Corsair Dominator GT 2133mhz cas 9 @ 1.5V
    MSI GTX970
    Samsung 830
    Intel 320 SSD
    Corsair AX 860i PSU
    Corsair Carbide Air 540
    Swiftech H220-X
    Creative Sound Blaster ZxR
    Logitech G15 Keyboard
  10. #10
    ROG Member Array
    Feb 2012
    11
    Vouch for setting Turbo Ratio from Auto to By All Cores
    Had the same issue as you guys and this is what fixed it for me when setting up X.M.P
    Changing the Clock Gen Filter had no effect for me.
    F3-14900CL9Q-16GBZL
