+ Reply to Thread
Results 1 to 9 of 9
Thread: How much radiator surface area to cool 4x 7970's to a decent delta of maybe, 10c?
    ROG Guru: Yellow Belt Stu @ MSD +10
    Feb 2012
    Location
    Blackpool. UK
    125
    Hi guys,
    Just ordering my EK waterblocks and backplates and now need some radiators, and its just occured to me that I am a little unsure as to how much cooling area I need.
    Will either add this loop into my existing 360 rad, or create a sperate one just for the cards and then add the chipset into the CPU loop, not totally sure yet, but one thing is certain, I want to run teh fans at very low speed as i am aiming for near silence.
    Currently, best value for money / performance seems to be the Phobya 1080 with stand.
    I really would appreciate any advice here as I am about to press the good old "Buy it now" button. LOL
    Asus Maximus IV Extreme Z
    i7 3770K @ 4.4ghz
    AMD 7970 HD x3 in TriFire @ 1200/1800.
    2x 240GHZ OCZ Vertex 3 SSD & 1x 512Gb Vertex 4
    8GB 2133mhz Dominator GT DDR3
    XFX Pro 1250w PSU
    Huge water loop with an internal EK 340mm & external Supernova 1260mm
    Windows 7 64 bit.
    Aquaero Fan control & monitoring
    ROG Guru: Black Belt Area 66 +20 Area 66's Avatar
    Jun 2011
    Location
    North of Montreal
    2,283
    Since you want to use low speed fan, I will create a loop for the GPU only and use push pull on this gorgeous rad ( I have the same one but quad only) You just have to find a way to vary the speed of the fans, what case are you using ? ( I know this rad will be outside )
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,747
    A decent rule of thumb is at least 120mm per card. If you want to run low speed then you might consider 2x 360 low restriction rads with some fans on a controller.
    I'm sure that external would work well; I'm just not a fan of detached rad boxes.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    Feb 2012
    Location
    Blackpool. UK
    125
    Quote Originally Posted by Area 66 View Post
    Thanks, am using an Aquaero controller so that is no problem.
    The case is a Corsair 800d which already has a 360 in the roof for the CPU.
    Quote Originally Posted by xeromist View Post
    A decent rule of thumb is at least 120mm per card. If you want to run low speed then you might consider 2x 360 low restriction rads with some fans on a controller. I'm sure that external would work well; I'm just not a fan of detached rad boxes.
    Nor I normally, but my particular room setup will mean its totally out of sight behind the desk in a corner where it cant even be seen.
    i7 3770K @ 4.4ghz
    XFX Pro 1250w PSU
    Windows 7 64 bit.
    Jun 2011
    Location
    North of Montreal
    2,283
    At least it's easy to clean when it's external, but easy to damage.
    here a pic of my similar quad rad, it's in a Mozart TX case, the problem was to find screw. I get them from a hobby shop, they are use in model cars or planes
    Feb 2012
    Location
    Blackpool. UK
    125
    Thanks guys, decided to go for the Phobya Extreme Supernove 1260 and 4x 200mm fans.
    i7 3770K @ 4.4ghz
    XFX Pro 1250w PSU
    Windows 7 64 bit.
  7. #7
    Jun 2011
    Location
    North of Montreal
    2,283
    Quote Originally Posted by Stu @ MSD View Post
    Oh MAN this is a sick RAD, I'm proud of you. this is a real ROG man......
  8. #8
    Feb 2012
    Location
    Blackpool. UK
    125
    Thanks, build pics here:
    http://rog.asus.com/forum/showthread...untry=&status=
    i7 3770K @ 4.4ghz
    XFX Pro 1250w PSU
    Windows 7 64 bit.
  9. #9
    Jun 2011
    Location
    North of Montreal
    2,283
    Ah it's you .. I post in the other post but I just realize it was the Sick Rad you talk about here
+ Reply to Thread
