+ Reply to Thread
Results 1 to 8 of 8
Thread: G53S Blu Ray Problem
    Hey guys,
    I recently bought a G53S rog laptop. It says it has a blu ray drive, and the cd drive is labeled as such. Under device manager it is listed as a : MATSHIBA BD_MLT UJ240AFW drive. Although it is labeled BluRay, I tried playing my friends Game of Thrones set and it would not read it, also tried a few others. Regular DVD's work fine though. Is the label on my drive misleading? it says all drivers are up to date but is there a special one I need to play blu rays? thanks for any help
    ROG Guru: Gold Belt dstrakele +75 dstrakele's Avatar
    Sep 2011
    Location
    USA
    4,357
    What player application are you using for the Blu-ray discs? I recommend trying PowerDVD Ultra 12. You can download a.free trial to troubleshoot.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    I tried using VLC and Windows media player. I really dont wanna have to pay for a video player
    ROG Guru: Blue Belt fuzon1337 +10 fuzon1337's Avatar
    Sep 2011
    Location
    Norway
    881
    Which version of the VLC do you have ?
    EDIT: VLC 2.0 supports blu-ray
    Asus G73SW-91058V 3D
    - Intel Centrino Ultimate-N 6300
    - BIOS 205
    Sep 2011
    Location
    USA
    4,357
    CinePlayer supports blu-ray and is pre-installed on ASUS laptops, but it is a buggy application and many report problems using it with blu-ray discs.
    I made sure i have version 2.0.1 of VLC and opening a bluray with VLC it read : Your input can't be opened:
    VLC is unable to open the MRL 'dvd:///D:\'. Check the log for details
    I do not see an option to open with Cinema. I bought this laptop slightly used, so it was possibly taken off for some reason.
  7. #7
    Sep 2011
    Location
    USA
    4,357
    What does the VLC log file tell you?
    You can download CinePlayer for your specific laptop model from the ASUS Support web site. It goes by the name SonicDVD.
  8. #8
    ROG Guru: Blue Belt PILGRIM +20 PILGRIM's Avatar
    Oct 2011
    Location
    China
    763
    Hi SIrChooCh.
    My G74 also came with the stock MATSH1TA BD-MLT UJ240AFW.
    As was mentioned, Forum members has been recommending 3 BD players:
    PowerDVD Ultra 12, (stock) CinePlayer, and VLC 2.0 version.
    Contrary to what others say about the CinePlayer being buggy, I'm not having
    any problems with it so far. As dstrakele said, you might want to download it
    and upgrade to 5.8.A06 version. It would be also useful to associate Blu-Ray or
    3D file types, and change Region Control (if need be), in the Settings menu.
    But for a better BD/3D player, buy the PowerDVD Ultra 12.
    Side note: Windows Media Player doesn't support Blu-Ray.
    ASUS G74SX-3DE
+ Reply to Thread
