+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: SSD problems on my G74S. HELP!
  1. #11
    ROG Guru: Black Belt BrodyBoy +20
    Oct 2011
    Location
    USA
    2,916
    Quote Originally Posted by ravincia View Post
    Gonna check on the SATA config now. I have no idea how to check the p128's firmware (i'm not sure if my ssd's up to date or not). I went to the corsair forums and the only update seems to be to enable TRIM. Anyway, i tried to update it but all the guides i've seen are as complicating as hell (it tells me i have to make a DOS bootable usb and update it through the bios --> they dont have a simple program to run from windows).
    I don't have that brand, but some SSD firmware updates must be done outside of Windows. With Crucials, for example, you burn a bootable CD with a file they provide.....it contains all the necessary software for the updating process. Maybe it's something like that....
  2. #12
    ROG Enthusiast ravincia +10
    Apr 2012
    31
    Quote Originally Posted by BrodyBoy View Post
    Okay, just checked my BIOS. SATA config is AHCI. The update process for the p128 is torturous. They provide the files, but its not an iso so i cant simply burn it to a cd. Futhermore, they say i NEED to make a DOS bootable usb but they don't show me how (which is pretty retarded). I feel like just giving up on the p128 and get a new ssd, would save me loads of trouble.
    Asus ROG G74SX-3DE
    Upgrading my gear as and when fate allows
    I'm an ENTHUSIAST just like you!
  3. #13
    ROG Member juv95hrn +10
    Apr 2012
    I have installed another brand of SSD and WIN7 cant even find it no matter if I put it to IDE or ACHI.
    Is that little tape like cable all that is needed? Does it send power to the harddrive through it? I'm trying to confirm that separate power supply isn't neccessary somehow.
    If if isn't why doesn't windows find my new SSD?
  4. #14
    Oct 2011
    Location
    USA
    2,916
    Quote Originally Posted by juv95hrn View Post
    Let's keep this conversation in the separate thread you started on it.
  5. #15
    Apr 2012
    31
    Okay, i managed to borrow my friend's acer laptop. I tried doing a clean install on the OS on his laptop and it works just fine. So i have come to a conclusion that its definitely a compatibility issue with the g74s. Seems like i'm gonna have to buy a new ssd after all
    Asus ROG G74SX-3DE
+ Reply to Thread
Tags for this Thread
