+ Reply to Thread
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 46
Thread: PC freezes, VGA led light displays red!
    ROG Member Hatton92 +10
    Apr 2012
    18
    Exclamation PC freezes, VGA led light displays red!
    Hey,
    I'm just going to post the events leading up to the problem and hopefully you lovely people of the internet can assist me as to where I have gone wrong and possible solutions for me to fix it.
    Code:
    My PC Spec:
    CPU:	AMD Phenom II X6 1100T 3.3GHz Black Edit
    RAM:	Corsair Dominator 16GB DDR3
    Motherboard:	AMD Crosshair V Formula 990FX DDR3 RoG Series
    Graphics Card:	AMD RADEON 6870 CROSSFIRE
    Sound Card:	Creative Sound Blaster X-Fi Titanium Fatal1ty Pro Series
    Headphones:	Creative Fatal1ty Pro Series Gaming Headset
    Mouse:	Microsoft Optical Mouse USB
    Mouse Mat:	RAZER DESTRUCTOR
    Keyboard:	Logitech Keyboard PS2
    Monitor:	LG W2363D 23" TRUE 120Hz 3D Widescreen LCD Monitor
    Operating System:	Windows 7 64bit
    1. The PC has worked fine for 6 months, gaming for long periods and no system crashes.
    2. I got a new desk set up about 1-3 days ago
    3. I decided it would be a good time to install my second graphics card (HD Radeon 6870)
    4. I didn't have the crossfire bridge to hand but left the card in the PC anyway to install the bridge at a later date.
    5. Booted up PC, worked fine for about 30 minutes
    6. Mouse froze, keyboard didn't respond, VGA led light displays as red!
    7. Tried to restart, monitor doesn't respond to PC.
    8. Red VGA led light is still on
    9. Have to turn off PC via the PSU switch.
    10. Wait over night.
    11. Turn on, boots up fine, freezes 30 minutes in. Same symptoms as #6!
    12. Turn off, wait 30 minutes
    13. Turn on, BIOS says 'overclock settings failed' (I've never overclocked any of the settings in my life)
    14. I decided to just set the overclock settings back to defaults and restart the PC
    15. Still freezes anywhere between 10-30 minutes in. Same symptoms as #6!
    16. I removed the second graphics card I initially put in
    17. Problem still persists. Freezes 30 minutes in, can't move mouse, can't operate keyboard, VGA led light displays as red.
    If any of you can help me out I would really appreciate it, this one has really got me stumped and I don't want to do anything else incase I create further problems.
    Thanks in advance,
    Hatton
    ROG Guru: Green Belt NemesisChild +10 NemesisChild's Avatar
    Sep 2011
    Location
    Paradise
    512
    You missed listing one of the most important system components, your PSU make & model?
    Intel i7 3770K@ 4.8GHz
    Corsair H70 Core Hydro
    ASUS Maximus V Formula
    16GB G.Skill RipjawsX@ 2133MHz, 9-11-11-31
    SLI: 2x EVGA GTX 670 4GB SC+@ 1267MHz cores
    RAID 0: 2x Samsung 840 (256GB) SSD
    Storage: Seagate 1TB 7200 RPM HDD
    Corsair HX850W Modular
    Cooler Master HAF 922
    Win 7 H.P. x64 & Win 8 x64
    ROG Guru: Yellow Belt Mummy +10
    Aug 2011
    Location
    Finland
    223
    1: Do you have your Windows in normal hard drive (HDD) or is it in some SSD ?
    -- I didnt find that info from your specs and there is SSD that could freeze your system specially if they had old FW.
    2: Did you uninstal your Graphics Card drivers before you installed your secend card in?
    -- Uninstall your current drivers via controllpanel and do "clean install" with new ones from AMD.
    Do not install them over the oldones!
    3: What Red VGA light you mean?
    -- The one on Monitor, on VGA card, on Motherboard?
    And welcome to Forum
    That overclock fail bios info was because you did shot down the pc via PSU swich.
    Next time press and hold your pc power button on the case down like 10 sec and it will force it down via MB.
    CPU: AMD FX-8150 MB: ASUS Crosshair V Formula DDR3: 2x4GB G.Skill Sniper DDR3-1866
    GPU: ASUS 7970 SSD: 4x Corsair F3 120GB @ Raid0 PSU: SF Golden Silent 500W OS: W7 Ultimate 64bit
    ROG Enthusiast DarkSilence +10
    Jan 2012
    Location
    Bonaire, GA
    27
    I had a similar incident with the red VGA led. My computer just would not boot up. I found that I had a bad stick of RAM.
    Crosshair V Formula Motherboard
    AMD FX-8120 8-Core Processor
    Corsair H100 Liquid CPU Cooler
    16GB Kingston HyperX DDR3 1600MHz RAM KHX1600C9D3K2
    Two MSI N560GTX-Ti Twin Frozr II/OC 1GB Video Cards in SLI
    Windows 7 64-Bit Home Premium
    Corsair HX850w 80 Plus Silver Power Supply
    1TB Western Digital Caviar Black 7200RPM 64MB Cache SATA 6G Hard Drive
    LG Super Multi Blue BH12 Blu-Ray Disc Rewriter
    Corsiar Carbide Series 500R Mid Tower Gaming Case
    Apr 2012
    18
    Quote Originally Posted by NemesisChild View Post
    850watts Corsair HX
    Sorry, Windows is installed on my HDD. I use my SSD for Steam.
    I didn't update the drivers because I hadn't put the Crossfire bridge on the cards.
    On the motherboard.
    It can't be the RAM can it? Everything was working perfectly fine before hand.
    I really don't know what I should do! Thanks for the quick replies, I hope I can get this sorted as soon as possible.
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    12,811
    It can be your memory, in fact it could be many things. But lets take it one step at a time.
    First a question == did you use a anti-static band when you installed your second graphic card?
    Moving on.
    In BIOS F5 enter
    F10 enter
    Boot to OS
    Reset as soon as you are in OS.
    Run memtest just to remove your ram from the equation.
    Post back when you are done and we will take it from there.
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
  7. #7
    Apr 2012
    18
    Moving on.
    In BIOS F5 enter
    F10 enter
    Boot to OS
    Yes, I used an anti-static band when installing the graphics card.
    I've turned it on this afternoon but for some reason it isn't even getting to the Operating System anymore. My monitor doesn't display anything and the VGA led light on the motherboard still displays as red!
    Also, how would I go about running memtest? (for future sake)
  8. #8
    Dec 2011
    Location
    London
    12,811
    Download the version that you find easiest to use. I like the USB version 4.2
    Insert to PC
    Power on PC
    F8 and select your Memtest location
    Let the application run for at least 2 complete cycles
    That is about it.
  9. #9
    Aug 2011
    Location
    Finland
    223
    @Hatton92, How you have your ram layout, 2x8GB or 4x4GB ?
    -- Take as many out so you have only one in the MB (Last one on RED slot. Fartest from CPU) and try booting to, OS again. If it dont help try other memory stick and so on.
    Not even BIOS?
    MB still may recognise it in. Anyway i would try to update/downgread them if i get in the os. all so look how high your TEMPs are when you are in and it crases.
  10. #10
    Shut Up Stupid! DaemonCantor +125 DaemonCantor +125 DaemonCantor's Avatar
    Jun 2011
    Location
    Ohio, USA....
    2,193
    I had this problem on the CHIVF, as it turned out the PCI-E Slots were set by the factory really low ie: not enough juice to power two cards up. I upped the Voltage in BIOS and the problem went away.
+ Reply to Thread
