+ Reply to Thread
Results 1 to 9 of 9
Thread: need a little help with my build
    well first off i'm new here
    this is my build
    asus crosshair V formula
    amd phenom II
    8gbx2 corsair vengance ram
    400gb wd hdd
    250gb wd hdd
    the problem i'm having is that i can get into bios and to the boot menu. Once i choose cd it runs xp setup for a bit then i get a ntdlr missing ctrl+alt+del to reset.
    if i choose my hdd it resets.
    trying to figure out if what i got wrong wether in the hookup or bios.
    got my 400 going to sata 0, other hdd and optical drives going to 1-4 sata.
    bios is set to default settings.
    i know its gotta be a corrupt boot file. but i can't even format or repair windows. the keyboard and mouse stop working when i get to those screens. and i have usb set to legacy.
    any ideas?
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    12,715
    Go into BIOS
    F5 enter
    F10 enter
    During the POST process F8 and select your CD/DVD with the OS disc
    Install OS
    Enjoy
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
    thnx i'll try that when i get home tonight hopefully it'll work
    just to clarify the hook up
    ok i have the bootable hdd on sata 0( the stand alone sata connector)
    i have my other hdd dvd player and dvd burner on sata 1-3 on the 1-6 connectors is this correct or is there a certain way i should have these in there?
    Shut Up Stupid! DaemonCantor +125 DaemonCantor +125 DaemonCantor's Avatar
    Jun 2011
    Location
    Ohio, USA....
    2,193
    I'm not the CHVF expert like HiVizMan but from what I've done on the CHIVF you need to hook up the DVD Burner into the Single SATA connector and the HD to the SATA port 1, Now the Funky thing is in BIOS set the SATA Ports to HD and the SATA Speed to SATA II or SATA300 because XP doesn't Support ACHI out of the box unless your on Service Pack 2 or better and even then it's Hit and Miss thing. The Motherboard seems to like setting the Speeds manually for some stupid reason. I know if I don't it will default to SATA III or SATA600 and refuse to boot at all.
    ok i switched around my cables as suggested. now it says pcie2 not found.
    tried the f5, f10, booted from disk setup ran then i got bsod'd.
  7. #7
    ok i got it to boot my hd and managed to get into windows loading the asus mb disk now and will continue throughout the night to load everything i can think of. pray for me
  8. #8
    well loading everything and its going well all but it doesn't see my dvd burner and 400gb hd
    got the hd in sata 0 and the burner in 1-3 it sees the other hd and dvd drive tho any suggestions
  9. #9
    Dec 2011
    Location
    London
    12,715
    Keep us informated as to how it pans out.
    It sounds like you might have a slightly corrupted BIOS? Download your fav BIOS (not sure the latest is the one you need think it was 705 for pre Bulldozer but might me wrong here) and extract to a FAT formatted USB stick.
    Boot into BIOS
    F5 enter
    F10 enter
    Back into BIOS
    Navigate to Tools
    EZflash2
    and flash your bios.
+ Reply to Thread
