+ Reply to Thread
Results 1 to 4 of 4
Thread: Intel WIFI Centrino Advanced N 6235 in G73JW?
    Question Intel WIFI Centrino Advanced N 6235 in G73JW?
    Hi Everyone,
    I've had enough with the stock Atheros card in my G73JW - it just started BSOD'ing for me again for no apparent reason (I think it has to do with number of open connections).
    I want to replace it with an Intel card. I was going to order a 6230 which seems to be what everyone orders, but I noticed Intel has released the 6235. It's a new card apparently and even though I don't see many differences I also see no point in upgrading to old hardware! ;-0
    So, my question is, does anyone know if the 6235 will slot right in just the same way the 6230 will?
    Here is a link to the card:
    http://www.intel.com/content/www/us/...ed-n-6235.html
    Also, On the net I see two different SKUs for this hardware: 6235AN.HMWWB or 6235AN.HMWG
    Does anyone know what the difference there is, if any? I think it has to do with the packaging but I'm not sure >.<
    The reason I need to research it well is I live in Costa Rica and will have to have the card courier forwarded for me - so returns aren't really an option!
    Thanks!
    Cody
    ROG Guru: Blue Belt fuzon1337 +10 fuzon1337's Avatar
    Sep 2011
    Location
    Norway
    881
    Hi
    The card looks like the others, so I will suspect that it will fit just fine in your notebook
    About the SKUs I don't know..... when I was looking at Ultimate-N 6300 there were to version 1 cheap one and one pricey one :S (and they got two different SKUs....)
    Asus G73SW-91058V 3D
    - Intel Centrino Ultimate-N 6300
    - BIOS 205
    Helium Chilled MarshallR@ASUS +20 MarshallR@ASUS's Avatar
    Dec 2011
    Location
    ASUS HQ Taiwan
    3,571
    It looks like standard mPCIe so it will fit just fine!
    Richard Swinburne
    ROG HQ
    Innovate. Never Imitate.
    When I get reeeally sad about missing someone far away, I just take a deep cleansing breath, then switch to the rifle with a scope.
    Thanks,
    I got a reply on the Intel forums saying that the difference in SKUs is just the bulk order, one SKU is what a builder gets when they order in boxes of 10s, the other is when they order in boxes of 100s. They are however the exact same hardware. I'll be ordering soon :-)
+ Reply to Thread
Tags for this Thread
