+ Reply to Thread
Page 6 of 13 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 126
Thread: Standby problems with OC - locked multiplier at 12x after wakeup
  1. #51
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    13,672
    Atlas my retails CPU's are here. I have 4 that I can test with, 2 K version and 2 locked multi.
    Do I still have to play (test) or are you happy with the solution you have found?
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
  2. #52
    ROG Enthusiast Atlas100 +10
    Apr 2012
    36
    Hi there,
    sorry for the late answer but I decided to exchange both CPU and Board....and guess what?
    Still got the same probs - EXACTLY the same....
    So am I right when everything points to the RAM?
    Can you give me a definetely working quad channel 16GB recommendation?
  3. #53
    Dec 2011
    Location
    London
    13,672
  4. #54
    Super Moderator Shamino +10
    Jul 2011
    Location
    tw
    461
    try this bios
    http://www.datafilehost.com/download-31bc4f1a.html
    manually set clockgen filter to disabled (as opposed to auto)
  5. #55
    ROG Enthusiast GetMax +10
    Dec 2011
    Location
    Sweden
    37
    The bios file seems to be corrupted. After I updated (first time in windows, second time from bios) I received the message "WARNING! Bios recovery detected. Insert flash and so on. I had to switch back to my current bios.
    Intel 3930K @ 3.8ghz C1 @ Offset Auto @1.3V
    ASUS Rampage IV Extreme (BIOS-1201)
    16 gb Corsair Dominator GT 2133mhz cas 9 @ 1.5V
    EVGA Classified GTX570 SLI
    Intel 320 SSD
    Corsair AX1200 1200w PSU
    Corsair 600T
    Creative X-FI Fatal1ty Pro
    Logitech G15 Keyboard
  6. #56
    Apr 2012
    36
    @HiVizMan
    Hi there - so....yesterday my alternative RAM Modules arrived. These are for the 1st try Corsair Venegance CMZ16GX3M4A1600C9 4x4GB.
    The booklet reports these explicitly as working and tested RAM for this mobo - BUT: SAME (!) probs here.....multiplier keeps locked with optimized settings...
    So: I exchanged CPU, Mobo and RAM and still got the probs. So for me it CANT be hardware related?!
    Could you please test this again? I took these components out of the box and it didnt work and i CANT believe that I'm alone out here with this prob (except the other guys in this thread).
    I will receive some Gskill RAM on Monday and try this again....but I think without any luck...
    @Shamino
    Could you please up the BIOS again? This one is corrupt and will not work...
    Thx
    Atlas
  7. #57
    Dec 2011
    Location
    London
    13,672
    alles klar
  8. #58
    Apr 2012
    36
    @HiVizMan
    so what does "alles klar" mean? Are you awaiting my test with the other RAM?
    Did you have any luck trying to get the problem reverse engineered at your system?
    I'm really thinking about getting rid of the RIVE and change to another manufacturer - BUT: the rive is the best board out there at the moment....so what to do?!
  9. #59
    Dec 2011
    Location
    London
    13,672
    LOL it means back to the test bench I go.
  10. #60
    Apr 2012
    36
    ahhhh
    btw - are you in contact with ASUS or do you belong to them? Just wanna ask if you can report them bugs they can put into the maintenance stream for the BIOS?
    Thx for your support!!!!
+ Reply to Thread
