You will not believe this, 'cos i hardly believe my own luck!!! 4.7ghz@1.33v and 4.8ghz@1.36v stable in Prime95 and OCCT for hours!!! 4.9ghz@1.42v Extreme Phase and Speedstep on (voltage goes up to 1.51v under load) is usable 24/7 and gives no errors in both Prime95 and OCCT, but when putting under good load i can't keep it from reaching 90-92C temps which scares me and i turn it off after 4-5 minutes. I tweaked it for hours to find the best settings for 5.0ghz and the best for me was 1.43v + Extreme Phase on CPU and VCCSA on Extreme also (with other stuff tweaked also). Voltage goes up to 1.53 under load, speedstep is on to keep it as cool as i can when it's off load. It is very much usable 24/7, even stable in OCCT (untill again it reaches 90+C degrees), but picky about Prime95. I run both Cinebench and 3DMark 11 @ 5.0ghz (will post pics it the next post). So far this is the best chip i've had in my 16 years of PC building. To be able to run this kind of clocks with 32gb 2133 ram is beyond amazing, too bad my Corsair H100 is not keeping those temps down enoughBut hey, i'm happy with stable 4.7ghz @ 1.33v any day
(I need 1.300 vcore @ 4.2ghz to be stable =P)
