NB/SB errors
Turbo123
Ok so for a back story refer to this: http://rog.asus.com/forum/showthread.php?9016-AMD-FX-8120-Zambezi-Temperature
Crosshair V Formula
FX-8120
I have actually gotten a new cooler it is the "ZALMAN CNPS9900MAX-R 135mm Long life bearing CPU Cooler Red LED" And it's installed and everything is running inside. Now I have an issue, My temperature from HW Monitor is saying my cpu cores are running at 25-30 C. And that is much better than my 40-65 C I had before. But now I am getting these AI Suite messages popping up giving me these NB & SB errors.
Now I didn't actually catch it with PRINT Screen but I can show you the red stuff on my AI Suite program,
http://i40.tinypic.com/3skcj.png
*NEW PIC*
http://i40.tinypic.com/9licnq.jpg
(Middle Monitor)
Anyways why are they all red?
The only thing I switched from the BIOS after installing my fan was Turbo Core to Auto instead of off.
Also are my temps good? I mean HWMonitor has always been WAY more defined as to what i'm running but I have heard I should only have 1 monitor installed and I would imagine an ASUS monitor would be better right?
Thanks for any help!
EDIT:
I turned Turbo Core off and I get V now in everything... Thankfully my computer didn't "Explode!!!" 😄 Can anyone tell me why Turbo Core is doing this?
Current Setup:
Crosshair V Formula
FX 8120 AKA Bulldozer AKA Zambezi
Crosshair Vengeance 8GB (2x4)
XFX AMD Radeon 6950 2GB
PC Power & Cooling Silencer MK|| 950W
Antec Darkfleet (DF-85)
HiVizMan
Level 40
Not a given that the ASUS monitor would be better. HWMonitor is a top application and I tend to trust it more than I would A1Suite
Turbo123
Yeah it turns out it only popped up the messages when I had HWMonitor running with the AI Suite. I uninstalled AI Suite because HWMonitor kept saying I had v... Needless to say AI Suite is broke. 😄
Current Setup:
Crosshair V Formula
