+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
Thread: Rampage IV Extreme error code 00
    ROG Member Rapid7 +10
    Jul 2011
    Location
    Darlington, UK
    14
    I've had my system running fine for 2 weeks (Stock settings no overclock) and today i get the 00 error code on boot.
    I'm running the latest bios 1202,and the only way i can get the sytem to boot is by using the usb/rog connect bios flash method.The pc will run fine then after 5 or 6 reboots the error code will appear again & i have to re-do the bios flash again.
    I'm running the following.
    Intel 3820.
    16Gb Gskill 1600mhz ram 9.9.9.24.
    Nvidia GTX 680
    Crucial M4 SSD.
    Corsair HX1000 PSU.
    Also since this has started too happen the PCH fan wont work?
    Please help as this is doing my head in
    Jul 2011
    Location
    Darlington, UK
    14
    I have checked the cpu socket for bent pins & they are all fine,if i shut the computer down and then restart it i get the error code straight away.I then have to shut the pc down again and switch the power supply off & leave it off for around 10 mins & it will then boot but the bios resets itself so i have go back into the bios & change some settings.
    What happens when you switch to the 2nd BIOS by pressing the red button that is labeled BIOS_SWITCH on the PCB at the bottom right corner of the board (under sata ports). Does it stay stable on that BIOS? I would stop flashing the BIOS using ROG connect if you are already on the latest 1202. Do you get any other red LED lights under the debug code? Have you tried a CMOS reset? We need to know more specifics of what you have tried.
    Jul 2011
    Location
    Darlington, UK
    14
    I have tried all of the above including the 2nd bios,cmos reset,removing the battery & no other lights under the debug code. Once the computer does boot it is stable & don't have any problems at all untill i shut down and go to switch the pc on again.
    ROG Enthusiast Baalberith +10
    Feb 2012
    Location
    Netherlands
    46
    u might give 0018 a try. runs very stable here for quiet a while now at 4.4Ghz@1.28v
    Intel Core i7 3960X 4.4Ghz @ 1.28v
    Asus Rampage 4 Extreme
    32GB Corsair Vengeance 1866 Reds
    Corsair H80
    Corsair AX1200
    2 x M4 Crucial 128GB
    3 x 2TB WD Black
    2 x XFX GTX285 BE
    Dell U3011
    Jul 2011
    Location
    Darlington, UK
    14
    How would i go about getting the 0018 bios?
    Thanks, Paul.
  7. #7
    Feb 2012
    Location
    Netherlands
    46
    R4E 1103 New BIOS
    0018
    http://www.datafilehost.com/download-03f241a9.html
    updates some pcie codes
    open range off vga core to -222
    Edit/Delete Message
    Made by Shamino, hes the wonderguy of ASUS :P
    Greets,
    Remco
    Corsair H80
    Corsair AX1200
    3 x 2TB WD Black
    2 x XFX GTX285 BE
    Dell U3011
  8. #8
    Jul 2011
    Location
    Darlington, UK
    14
    Many thanks, touch wood that new bios has fixed my error 00 code
    I have shut down & restarted around 10 times and not one single 00 code has appeared.
    But for some reason my PCH fan is still not working but i'm not too bothered about that.
    Many thanks.
  9. #9
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    12,754
    Cheers Ballberith for stepping up to bat.
    Rapid7 keep us informed as to how things pan out with the new BIOS
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
  10. #10
    Jul 2011
    Location
    Darlington, UK
    14
    Will do,any idea why the PCH fan has stopped working as i turned it off the previous day before all this started happening & i have not go it working since? Also can i ask what causes the error code 00 and how this bios fixes it?
    Thanks.
+ Reply to Thread
