NB Fan replacement
icecube
Hi, I just got a new R3E board and the fan supplied was DOA, ASUS tech support tells me the fan is not covered under warranty. Where do I get a new one??
I can't believe I just spent 400 dollars on this top of the line board and get brushed off by the company 😞
Thanks!
Hapatingjaky
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185039
Will fit just fine.
Intel Core i7 5930K @ 4.8GHz, Asus Rampave V Extreme U3.1, Kingston HyperX Fury 2666MHz 32GB DDR4 ( 4x8GB ), Nvidia GeForce Titan-X SLI, Creative Labs E3 USB Soundcard, Samsung 950 Pro 512GB M.2 NVME, Corsair AXi 1500i PSU, Corsair 900D, Corsair K95 RGB Keyboard, Logitech Proteus Core Mouse, Acer Predator X34 @ 100Hz, Sennheiser Gamer Zero, Windows 10 Professional
Nice!! bought it, thanks!!
Retired
Not applicable
I would recomend replacing the stock fan anyways, as it has a pretty bad air flow rate and tends to start vibrating fiercely.
