64 Bit Windows 7 Ultimate,
Rampage IV Extreme motherboard,
32GBs of G. Skill Ripjaws Z series 19200 PC3 RAM (that's 2400MHz by the way),
2 Western Digital 2TB 6GB/s HDD,
Intel I7 Extreme 3930K Step C2 Processor (from the UK),
Noctua NH-D14 Cooling unit,
Silverstone Strider 1500W PSU,
Sapphire Radeon HD 7950
Nice system.
1) Update your driver to 12.3 - download the full package. And is there any reason you are not using the March 2012 version of UDK?
2) Run memtest (Ver 4.2 USB stick is the one I use - but there might be a later version) I suspect your ram is not stable.
3) Your TV what is the native res of the set? HDMI from your graphic card needs to be set the same as the TV.
4) What is your LCD screen res? Issue with screens which are not native HDMI res.
5) If you are not using Bluetooth disable in BIOS, if you are using Bluetooth install the drivers.
6) Suspect that your sound drivers are installed just fine, but that you have not configured your playback nor your record default hardware as yet.
7) Window7 will show each and every wifi within range, I am talking the OS here. What ever software you have installed will act independently of that. Best thing is to do your OS install with a network cable connected and plug your stuff in, that way the OS automatically downloads any drivers that are needed. I too use a wifi dongle and that is the method I used as I found the software that came with the dongle bloated my system.
😎 I hear you, expectation is a killer when it is not realised. Wait until l you marry you will understand even more then. (jk dear no really - don't pick up that cast iron skillet)
😄Mate we do stuff cos we are all part of the ROG family. Post up some of your artwork here anyway - the forum is full of art critics. DC this is for you and Chris.
