+ Reply to Thread
Results 1 to 7 of 7
Thread: CPU_LED and no display
    Exclamation CPU_LED and no display
    Hello, I was wondering if I could get a bit of help with my motherboard.
    I've got an issue extremely similar to this one here, except that my CPU_LED won't turn off.
    My motherboard is a ASUS Crosshair V Formula AM3+ AMD 990FX, which I believe is running the default BIOS 1102. It was purchased through Newegg, arrived undamaged, was installed as I was grounded, and was installed as guided.
    The motherboard appears to be working normally at first glance, as it powers all of the fans normally, lights up, and is startable using the power button on the case's front I/O. However, when I power it on, the red CPU_LED light remains on and nothing is displayed to my monitor no matter what I do.
    The red CPU_LED light remains on even after I remove or reposition the CPU, empty all but one DIMM slot, remove the GPU, reset the CMOS, turn ROG Connect on/off, and disconnect my hard drive. All of the pins on the CPU are unbent, the board's LEDs indicate that everything is receiving normal voltage, and everything on the board appears normal.
    This is a brand new build, so I can't swap any pieces out to determine other issues which could cause this problem, but the issue seems to me to definitely be the board itself.
    If there's anything I could do to avoid having to submit an RMA, that would be wonderful. I want to get this working ASAP.
    Here are my build's specs-
    Case: Antec DF-85 Black Steel / Plastic ATX Full Tower Computer Case
    RAM: G.SKILL Ripjaws Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
    CPU: AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop Processor
    GPU: An inherited ASUS 9400 GT, the only not-brand new piece in this build. Confirmed to work in another machine.
    PSU: OCZ Fatal1ty 750W Modular Gaming 80Plus Bronze Power Supply
    Mobo: ASUS Crosshair V Formula AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Gaming Motherboard with 3-Way SLI/CrossFireX Support and UEFI BIOS
    HDD: Seagate Barracuda XT ST33000651AS 3TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
    Super Moderator HiVizMan +150 HiVizMan +150 HiVizMan's Avatar
    Dec 2011
    Location
    London
    12,678
    May I ask why you assume that is the default BIOS?
    If you look near your 24pin power connector there is a white sticker that has a long number the last four digits should be the BIOS your board was shipped with. Could you check and see that your BIOS is indeed 1102?
    I suspect that it might just be pre-705 and that means you will need a bios flash for your CPU to be seen.
    3 series MIVE, MIVG BIOS FLASH GUIDE
    RAID GUIDE * Memtest86+ GUIDE * CAP GUIDE * USB BIOS Flahsback GUIDE * Win8 Rampage Install
    ONLY IF 2003 BIOS or NEWER
    To Flash back to 1xxx.ROM, Rename 1xxx.rom to ERALL.ROM and Use USB Flashback
    ROG Guru: Orange Belt ganji +20 ganji's Avatar
    Apr 2012
    Location
    worcester uk
    440
    when i bought my v formula lst week the bios version was 0404
    Corsair Carbide 500R
    Crosshair v formula
    AMD Fx-6100 4.5GHz
    Corsair H100i 2x Cougar Vortex
    Corsair Vengeance 2x4GB DDR3 1600. 9,9,9,24
    Palit GTX 670 Jetsream 2GB Sli
    Corsair AX 850
    OCZ Agility 3 120Gb
    Hitachi 1TB
    2x Hanns-G HL231
    3840x1080
    Quote Originally Posted by HiVizMan View Post
    My assumption came from reading that sticker, so I guess I can confirm it's 1102.
    I can't even see whether or not the board makes it to BIOS because it won't display anything.
    Fixed it.
    I am an idiot.
    Apr 2012
    Location
    worcester uk
    440
    glad u got it sorted
    Crosshair v formula
    AMD Fx-6100 4.5GHz
    Corsair AX 850
    OCZ Agility 3 120Gb
    Hitachi 1TB
    2x Hanns-G HL231
    3840x1080
  7. #7
    Dec 2011
    Location
    London
    12,678
    Quote Originally Posted by tinfoil View Post
    Fixed it.
    I am an idiot.
    LOL You can not leave us hanging like that. Come on fes up what did you do?????
+ Reply to Thread
Tags for this Thread
