As I’m getting older learning new things is getting harder... Man, how many times I clarified for myself that the 5V and 12V are in the same rail! Well, I really appreciate this thread – by the end will get all this things correctly... hopefully...
Regarding my post #30, xeromist didn’t answer my question: How I’m getting different wattage value using the same PSU calculator with the same components? I was asking you to check if I didn’t miss anything filling up that form.
You’ve got 981W versus 648W I’ve got as result. That’s serious difference, DaemonCantor! How that happened?! Since then every day, multiple times checking it but every time gives me the same result: 648W. You’ve mentioned the Newegg’s PSU calculator, with the same hardware – that’s much simplier (asking for less info, offering less choises), I choosed CPU: AMD Phenom X4, high end desktop motherboard, one HD 5870, two sticks of 4GB DDR3, two blurays and three 5400rpm 3.5” HDDs. Guess what? “Our recommended PSU Wattage: 624W”! It seems pretty consistent with the Thermaltake’s one...(considering that is asking less things, so giving lower value). That’s far less than 1192W you were talking about...
I’m really trying to understand how you, DaemonCantor, came up with those high wattages! I could accept that different calculators may show different results (that’s why you should rely on the values obtained on a wattage meter at the wall), but the same calculator with the same parameters is giving the SAME results...
“Now remember the link I posted on the power of the 5870 that same system would need a 350watt + 354watts = 704watts minimum with out any room for possible extra power but you still have to add that into it and like I was saying you need a minimum of 30% for reserves which in this case is 212watts so now were at 704w + 212w = 916watts.” – are you reffering to post #12 (and this link: http://www.tomshardware.com/reviews/...2422-20.html)? Just because the wattage value of 354W given there for a single HD5870 is the whole system’s consumption, not the graphic card’s only! So from where did you get the extra 350W to end up with 704W?!
“Like Kipper stated basically 'Do the Math!'.” – yeap, man, but if you’re using a formula, then explain each value you put there!
As I said, I’m really trying to understand these things...
