+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: 2600k on dry ice
    MIA ROG Guru pcjunkie209 +10
    May 2010
    Location
    Stockton,CA
    1,038
    2600k on dry ice
    I will do some dice in the am tomorrow and post some pics. Retail 2600k is D2 revision and my understanding is D0 & D1 is no good at subzero FYI.
    "I would rather be gaming!" Grunts-clan.com
    http://Pcjunkiemods.com
    http://c2cmods.com
    May 2010
    Location
    Stockton,CA
    1,038
    Well no point in putting up pics. Sabertooth is no good on oc. Unless I did something wrong. I tryed everything. 4.8ghz on stock cooler or pot that's it. I am gonna get a different board. IMO don't buy if gonna oc past that or until newer bios release.
    http://c2cmods.com
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,754
    Bummer I'm thinking it may take a generation before the manufacturers work out all of the kinks.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    ROG Guru: Yellow Belt 69_Goat +10 69_Goat's Avatar
    Jul 2010
    Location
    Alberta, Canada
    145
    What bios are you using?
    There are a couple new bios here:
    http://www.hwbot.org/forum/showthread.php?t=15952
    i7-980X | EVGA 762 Classified | 6GB Dom GT 2000C7 | GTX580 SLI
    i7-2600K | Asus MIVE-Z68 | 4GB Dom GT 2000C8 | GTX580 Martix
    69_Goat's HWBOT Profile
    May 2010
    Location
    Stockton,CA
    1,038
    thanks Goat i'll try again. i checked Asus website and i have the one they have how come these aren't there?
    http://c2cmods.com
    ROG Guru: Blue Belt martin_metal_88 +10 martin_metal_88's Avatar
    Apr 2010
    Location
    Quebec
    812
    Can;t wait to see some result dude! Carry on and don't kill it
    Martin_metal_88
    Colenzo :Coolermaster ATCS 840 | Gigabyte's EP55-UD5 | Intel Core I7 860 @ 3.8Ghz | 4GB G.skill Trident 1600 | MSI GTX460 1GB HAWK Twin frozr | WD 640 black + WD 1TB green + WD 1TB Blue | Pionner DVR-216 | Silverstone Strider Plus 850W | Coolermaster Hyper 212 plus in push pull fan config |
    Ask for more!
  7. #7
    May 2010
    Location
    Stockton,CA
    1,038
    Ok Goat I just updated bios. We will see what happens. Gonna start with air. I'll update this tonight.
    Update- a little better 5.3ghz
    http://c2cmods.com
  8. #8
    New ROGer elmy +10
    Jan 2011
    Location
    Seattle
    2
    If you have say ram that is rated at 2133 run it at 1866 and ram rated at 1866 run it at 1600 and so on. Run it at one rating less than it is rated at. That is what I've experienced so far. Also get ram rated at 1.5 volts instead of 1.65 also helps out in a few cases as well.
  9. #9
    SB does very poorly at sub ambient temps.
    the best you can do is a nice air cooler, even water is overkill.
    Trust me, a bunch of us over at OCN tried, but dice/ln2 doesn't help anything
    http://valid.canardpc.com/show_oc.php?id=1606285
    ^that was on air, with a broken bios
  10. #10
    May 2010
    Location
    Stockton,CA
    1,038
    Quote Originally Posted by elmy View Post
    i have a 2000 kit running at 1066 till i find stablebility then i wil dial in ram.
    Quote Originally Posted by reflex99 View Post
    well FYI my D2 chip seems to run sub temps ok but i am tryin to find air threshold first. also i am using 1253 bios on sabertooth
    http://c2cmods.com
+ Reply to Thread
Similar Threads
  1. Unboxing of Sabertooth P67 & 2600K
    By pcjunkie209 in forum NON-ROG Intel Motherboards
    Last Post: 03-18-2011, 01:55 PM
  2. i7 2600k bigadv results
    By dvast8n in forum Folding@Home ROG Team 183368
    Last Post: 02-13-2011, 07:48 PM
  3. bigadv folding comparison i7 920 vs i7 2600k
    Last Post: 01-16-2011, 07:46 PM
  4. 2600k vs 980x?
    By glw165 in forum Rampage Series Motherboards
    Last Post: 01-06-2011, 11:27 PM
