+ Reply to Thread
Results 1 to 2 of 2
Thread: Folding@Home - Bonus points qualifications
    TeamROG Folding@Home ottoyu34 +10 ottoyu34's Avatar
    Apr 2010
    Location
    Canada
    753
    Lightbulb Folding@Home - Bonus points qualifications
    In order to maximize ppd out of a high-performance cpu such as core i7. You need to take advantage of the bonus point system. There are bonus for returning WU quickly. The system applies to A3 core and -Bigadv folding. Below is a few guidelines:
    1. Run the latest SMP client (v6.29 or above).
    2. Configure that client with a passkey.
    3. Complete 10 a2 and/or a3 work units...
    a. within their preferred deadlines
    b. using the same passkey and fah user name combination
    c. on one or more of your systems.
    4. Successfully return >=80% of assigned [bonus] WU's.
    Once you got 10 WU finished. That specific passkey and user name will qualify for bonus point in A3 core SMP folding and -Bigadv. In order to monitor you bonus ppd, Fahspy and HFM.net both support bonus points calculations.
    The bonus applies after you've done 10 a2 or a3 WUs provided you have used the same passkey and the same UserName on all applicable machines and provided you meet the 80% rule.
    Once that requirement has been met, the bonus currently applies to a3 WUs and to bigadv projects (at least for the time being). You can tell by looking at the last column of psummary.
    reference: http://foldingforum.org/viewtopic.php?f=58&t=13160
    |800D|Core i7 980X - 4Ghz - H2O|Dominator 1600 6GB|Rampage III Extreme - H2O|Nvidia GPUs|OCZ Vertex 120GB|Antec TPQ 1200W|
    ROG Guru: Blue Belt martin_metal_88 +10 martin_metal_88's Avatar
    Apr 2010
    Location
    Quebec
    812
    Have to add that once your Passkey have met the requierement you can do a fresh windows install and re set everything and you will have bonus at the first unit because your passkey already do bonus.
    Martin_metal_88
    Colenzo :Coolermaster ATCS 840 | Gigabyte's EP55-UD5 | Intel Core I7 860 @ 3.8Ghz | 4GB G.skill Trident 1600 | MSI GTX460 1GB HAWK Twin frozr | WD 640 black + WD 1TB green + WD 1TB Blue | Pionner DVR-216 | Silverstone Strider Plus 850W | Coolermaster Hyper 212 plus in push pull fan config |
    Ask for more!
+ Reply to Thread
Similar Threads
  1. Folding@Home - Extreme Overclocking folding@home stats - Team#183368
    By ottoyu34 in forum Folding@Home ROG Team 183368
    Last Post: 08-01-2011, 06:11 PM
  2. Folding@Home - Installing SMP client (CPU) + Bigadv
    Last Post: 03-28-2011, 08:11 PM
  3. Folding @ Home on EOC
    By irdmoose in forum Folding@Home ROG Team 183368
    Last Post: 06-26-2010, 01:01 PM
  4. Folding@Home - Tools
    Last Post: 04-15-2010, 02:57 AM
  5. Folding@Home - FAQ
    Last Post: 04-08-2010, 10:49 PM
