Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 31
    ROG Member Array
    May 2012
    9
    problems with g75v
    hi, i recently bought a g75v and have 2 problems with it. first problem is the subwoofer, i hear not only bass with it but also higher frequency, so the sound tends to be leftsided which is annoying.
    also i have problem with the keyboard lightning, first it was on, but now i cant turn it on anymore. i used the function keys to change brightness but it just stays off.
    any help for those 2 problems would be appreciated, otherwise the notebook is running great.
    ROG Guru: Blue Belt Array fuzon1337's Avatar
    Sep 2011
    Location
    Norway
    18
    878
    Hi and Welcome to the ROG forum!
    About the sound issue, I'm not sure how to fix that. Do you use the THX TrueStudio?
    The KB lights, I have two suggestions for that:
    • Use Windows Restore Point, and restore your notebook back to the time when it worked
    • Go to Asus support choose your version of Win7 OS, then go to utilities, download the driver named this: ATKACPI driver and hotkey-related utilities V.1.0.0016. Uninstall the ATK package you have, reboot, install the new ATK package, reboot, done.
    The KB lights does flash when the Asus splash screen shows up during bootup ?
    Asus G73SW-91058V 3D
    - Intel Centrino Ultimate-N 6300
    - BIOS 205
    ROG Member Array
    May 2012
    9
    thanks for your reply, i was able to fix it by simply rebooting...
    but the soundproblem with the subwoofer seems to be a problem many are having.
    on a website reviewing the g75v the tester mentioned the same problem, seems to be a driver problem.
    anyone else who bought a g75v, having success with a solution?
    also, did anyone get a reply from g75@asus.com because of the free download code for ghost recon?
    it seems there is a limited offer where when you buy the g75v before the 31/may you get a code to download the game for free, but i am still waiting for a reply.
    anyways i am happy, skyrim runs on everything maxed without throtteling or loud sound from the coolers.
    need to install bf3 so see if it performs also that well under more load.
    ROG Guru: Yellow Belt Array irdmoose's Avatar
    May 2010
    Location
    Orangevale, CA
    22
    151
    From my experience with my G73, it took a while (about two months) for Asus to ship a new bios/firmware/driver combination that fixed my G73's subwoofer overdriving. My guess is this is a similar issue, and will likely take a similar amount of time.
    May 2012
    16
    155
    Quote Originally Posted by calisto321 View Post
    Hmm i just got the G75 and it seems like the subwoofer isnt even kicking in...but when i do a TEST on the VIA HD Deck it kicks in... and all the sound seems to be coming from the left side only.
    ROG Member Array
    May 2012
    9
    chnnsar son
    try to see if changing to 2.1 in audio settings enables your subwoofer. i read in a review that fixed it.
  7. #7
    ROG Member Array
    May 2012
    9
  8. #8
    May 2012
    44
    233
    I'm experiencing the same audio issue where it sounds like everything's coming out of the left side and I can only really tell that the subwoofer kicks in when i'm running the test in the VIA HD Audio Deck. As for the suggestion to change to 2.1 in audio settings - isn't it already enabled by default? It didn't seem to change anything for me.
  9. #9
    ROG Member Array
    May 2012
    9
    it seems you have the same problem as me, subwoofer overdriving, thus sound coming from the leftside. there doesnt seem to be a solution for it sadly. someone posted above asus took 2 months to fix it on a previous notebookmodel with similat problem.
  10. #10
    May 2012
    44
    233
    Hopefully they can move a little quicker this round since they already had a similar problem on the previous notebook model...
