Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    New ROGer Array
    May 2012
    4
    Sound still coming out from speakers with headphones plugged in
    I have the G75VW-AS71 (Amazon model) and am having an issue with the sound sometimes. The sound still comes out of the speakers when I plug in headphones. If I click on the speaker icon to mute it and then unmute it, then the sound only comes out of the headphones as intended. I couldn't find any setting that would disable the speakers if headphones are plugged in.
    The driver I have for the VIA Audio Deck is current, according to the ones available on the ASUS Driver Page for the G75VW.
    Anyone else experiencing this issue?
    ROG Guru: Orange Belt Array
    Jan 2012
    Location
    Tejas
    317
    I'll attempt to duplicate it when i get home.
    G75vw DS71
    3610QM I7
    16GB Ram 1600mhz
    750GB+120GB(patriot pyro)
    Nvidia gtx 660m
    Purple Keyboard mod
    Proud Owner of a GTX 660ti DC-II
    ROG Enthusiast Array
    Feb 2012
    Location
    USA
    26
    Dunno if it'll be the same or not, but with my G74SX I started having that issues out of the blue about a month ago. I ended up d/l the latest drivers for the audio from the manufacturer site instead of ASUS, fixed my issue. I had done a fresh Win7 install, used the drivers from the ASUS site which didn't work for some reason.
    ROG Member Array
    May 2012
    11
    There is another thread that is dealing with audio issues in greater detail, but I assume this is a by-product of the fact that the sub woofer is being used when in headphone mode. You might want to turn off MonoBass (Windows Audio Settings) or LFE slider to 0 if using the VIA Deck software.
    If it's just 1 point above off, you'll most likely get sound out of the sub woofer. I think I noticed that as apart of my testing last night trying to narrow down the audio issues that some of us have noticed.
    ~ TD
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)G73JH, Lenovo Y500 SLI
    MotherboardASUS Maximus IV GENE-Z
    ProcessorIntel 2600K
    Memory (part number)16GB DDR3 1600
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Patriot PyroSE SSD
    CPU CoolerCustom WC loop
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    177
    5,673
    Quote Originally Posted by OldNESJunkie View Post
    +1
    I've had an issue with sound out of both on my G73 and it was because I had old drivers.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    ROG Guru: Platinum Belt Array WhitePaw's Avatar
    Jan 2012
    184
    5,996
    Shrooms?.............?
  7. #7
    May 2012
    45
    Quote Originally Posted by bObaBaLLa View Post
    Yes - having the exact same problem with the exact same laptop. (G75VW-AS71 from Amazon)
    Are you also experiencing "random audio and graphic spikes"?
  8. #8
    New ROGer Array
    May 2012
    4
    I am also experiencing this. What i do is, Go to speaker properties and on enhancements tab uncheck the 2.1 channel.
  9. #9
    New ROGer Array
    May 2012
    4
    Quote Originally Posted by zac31 View Post
    That disables the subwoofer though, right? That is an unacceptable "workaround".
  10. #10
    Jan 2012
    Location
    Tejas
    317
    Yes that would disable it. Supposivly there is a new driver out try that?
    G75vw DS71
    3610QM I7
    16GB Ram 1600mhz
    Nvidia gtx 660m
    Purple Keyboard mod
