Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
  1. #11
    ROG Member Array
    Jun 2012
    5
    Same Problem
    Got mine from CompUSA / TigerDirect -
    Returned it - Paid return shipping
    Got a new one...
    Same problem...
    Plug headphones in, Leave them in - walk away from PC, it goes to sleep
    Come back - log in
    Chime from windows (ie sound) can be heard from the laptop speakers - loud too...
    But the Headphones are still plugged in...
    Updated audio driver -
    Re-imaged (using recovery DVDs)
    Would be nice for BIOS update or firmware or sound drivers to be fixed...
    Yes, I tried using multiple headphones..
    Yes I did ASUS update
    No I don't have any additional hardware installed...
    I can't attest to any other problems - only used the laptop 3 or 4 times -
    and I don't play games - so not sure of the graphic card performance..
    G75VW
    It is less than a week old -
    I have tons of ASUS stuff - including a P79X Pro MB and a few eeePC's
    This is sad for me - tech support wants me to mail my laptop to them -
    screw that -
    they will just send me another one w/ same problem...
  2. #12
    ROG Guru: Yellow Belt Array Woots's Avatar
    May 2012
    Location
    Atlanta, GA
    49
    176
    I have G75 (bestbuy model) I also experience this issue. It seems to happen intermittently. I get audio that randomly starts playing out of speakers whenever it decides to do so. To fix it I have to unplug the headset and replug them back in again.
  3. #13
    ROG Enthusiast Array waynes26's Avatar
    May 2012
    Location
    Canberra Australia
    63
    Hi
    I had a go at trying to replicate the isue. But mine appears to be working ok.
    This is what i did.
    Play song can hear thru all speakers.
    Pluged in headphones, sound only thru headphones.
    Put laptop to sleep
    Woke it up started song again and sound only thru headphones.
    If i mised something let me know and i will give it a go.
    G75vw-91132v
    i7 3610QM
    16 GB SDRAM
    GTX 670M
    17.3" FHD 3D LED Backlight
    1x 240gb Intel 520 1x 1TB 5400rpm
  4. #14
    May 2012
    45
    Quote Originally Posted by waynes26 View Post
    As others have said, it's intermittent.
  5. #15
    May 2012
    Location
    Canberra Australia
    63
    Good new for me than, i have now gone thur it more than 10 times, and it is still ok.
    May be i got a good one??????
    G75vw-91132v
    i7 3610QM
    16 GB SDRAM
    GTX 670M
  6. #16
    ROG Guru: Orange Belt Array
    May 2012
    272
    dont be to sure about that bro, my g55 i tried to replicate the problem over 20 to 30 times but the sound doesnt comes out from the speakers when headphone attached..i was on cloud nine thinking that i got a good unit..all of a sudden, 3 days ago, the issue occured, i unplugged the hesdpones and attached them again and the sound from the subwoofer dissapear..then i tried to replicate again but didnt occur after that and since i updated my drivers..guess what im trying to tell it thats is occurs randomly due to driver issue..issue happened to me once and only once
  7. #17
    ROG Member Array
    Jun 2012
    5
    Hi
    This is what i did.
    Put laptop to sleep
    It is random problem - I can't find the exact pattern.
    Another way I have seen this happen:
    1.) put a DVD in - w/ headphones plugged in
    2.)Watch DVD with windows media player
    3.)pause DVD for 10-15 minutes
    4.)hit play on windows media player (headphones still plugged in)
    5.)audio comes out headphones as well as laptop speakers
  8. #18
    May 2012
    45
    I have this problem, but here is a temp fix, I just unplug and replug the headphones while the audio is still on, it seems to do the trick for me. It's quick temp fix.
  9. #19
    May 2012
    46
    You are right, unplug and plug back in and that fixes the problems.
    G75VW-BBK5
  10. #20
    May 2012
    46
    i don't think it is a hardware issue, it seems to be a driver issue.
    i uninstalled the via drivers and let windows sort out its own drivers. this has completely solved this problem, however using the Fn+volume keys no longer change the volume when headphones are plugged in, only when on speakers.
