AI Suite II Issue
Sim
Hello All
Im haveing an issue with AISuite_II_V10212_XPVistaWin7 (64)
Downloaded from asus web site....unpack the files got to run setup, asks me to open file security, so i click on run, and nothing happenes. Just wont install no error messages no nothing, i can see the process running in task manager
Anyone have similar issue ??
Thank you for you time.
MrRedHat
I had the exact same issue as you a few days ago. It seems that the ZIP file that I downloaded was corrupt. What I ended up doing was downloading it again, but instead used winrar to extract the file instead of Windows’ built in compression.
MrRedHat
don't install that crap guys. It's outdated and can cause issues from stability to outright bsod's.
HiVizMan
Level 40
Well I would not quite word it as strongly but I have to agree with the sentiment expressed.
Unless you are using the TurboV application there is little need in my view to install. I use HWmonitor to keep an eye on the temps and fan speeds. And the bios to set my fan speeds.
