Hey guys,
Have a strange issue here, and am hoping someone could shed some light on the problem.
Whenever I try to use offset vcore of any amount, my computer won't post or boot. It will just stay on 'no signal', and keep trying to reboot itself, until eventually the computer will just turn off. The last code I see before it shuts off is code 79. The only way to get the computer to boot again is to reset cmos.
On manual vcore it works great, boots fine, only require 1.36v, on auto offset it gives me 1.43. So logically I tried -0.05 offset. Had the possibility that idle volts was not enough, so I've tried making small increments to the offset, ie. -0.005 and +0.005 up to -0.05 and +0.05 and it causes the same result, no boot. The only way to get offset to boot is to use auto, but then there isn't much point to that.
I've tried turning off C-states, I've tried leaving LLC and other voltage settings on default. I've even tried resetting cmos, then touching nothing except the vcore offset voltage and it'll still not boot.
Any insight or solutions would be great![]()
