+ Reply to Thread
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 41
Thread: best settings for gaming
    Hi guys,
    I just installed my phoebus and was checking out the setting, I'm a bit of a noob.
    I do a lot of gaming on modern warfare 3 and was wondering if you guys can help me out: what are the settings to use for gaming ? dolby home theater v4 with the game tab?
    should I enable dx button?
    what does soundradar do?
    Is there a tutorial that explains all the new stuff?
    I had a xonar dx before and found that the best sound was with only dolby headphone enabled. My headphones are sennheiser pc350's.
    Thanks!!
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,802
    GX enables EAX features, use with games that support it. Sound Radar works with GX to enhance front speaker effects. EAX isn't used much now so most titles won't see any change from either of these functions.
    If you want to experiment with Dolby HT then use the Game preset with headphones, it adds a bit of depth.
    -Raja
    ASUS Technical Marketing
    If you are located outside North America and require technical assistance or support, please contact ASUS Support for your region.
    For ASUS North America Service: http://www.service.asus.com/#!contact-us/cw8z
    ROG Guru: Yellow Belt dedaciai +20
    May 2011
    209
    Quote Originally Posted by Raja@ASUS View Post
    -Raja
    I can attest to the Dolby HT Game preset. It rocks in my opinion. I can hear exactly where everything is and it's approximate distance relative to other sounds. Heck, I have been accused of hacking on BF3 a little more often now since I can here around what corners people are shooting from.
    Intel Core 3930K at 4.25GHz
    Asus Rampage IV Extreme BIOS 1404
    Crucial M4 SSD 256GB
    EVGA GTX 570 SC 2-Way SLI @ 822/2000/1.038V 24/7 Drivers: WHQL 301.42
    2 Caviar Black 1TB HDD
    Asus XONAR Phoebus
    Corsair H100 (p/p)
    Corsair Vengance RAM 16GB @1600MHz
    Enermax 1350W PSU
    Windows 7 Professional 64-bit
    ROG Enthusiast txfeinbergs +10
    Apr 2012
    35
    More questions on optimum game settings
    This has to be the most complicated sound card I have owned. What are the disadvantages / advantages of cranking the sample rate to 192 Khz and 24 Bits vs lower settings? I am mainly using the sound card for gaming.
    Also, the gaming preset in Dolby HT really doesn't seem like it enables much stuff by default i.e. equalizer settings all at neutral and no intelligent equalizer enabled. Also I noticed that the default has Surround Virtualizer on for both speaker and headphones, but the levels are set to minimum meaning it probaby isn't doing much.
    Apr 2012
    35
    Sorry, another question. Red light on the control box. When it is lit, does that mean it is muted, or unmuted?
    Apr 2011
    Location
    ASUS North America
    2,802
    Quote Originally Posted by txfeinbergs View Post
    This really depends on the sampling rate of the source material. If it is a 16 bit 44.1KHz music then I tend to play back at that frequency - not a fan of upsampling myself. Of course, it also depends on what kind of attenuation one is using and the playback software. If however we are talking files recorded at higher sampling rates and game effects then using 24 bit makes sense.
    As for your question on the red light, you can always plug some phones in and toggle between mute on/off to work that out.
  7. #7
    Apr 2011
    Location
    ASUS North America
    2,802
    Quote Originally Posted by dedaciai View Post
    Yeah I tried that out with BF3, it is quite profound.
  8. #8
    Apr 2012
    35
    Red light on is muted. I actually just hit the mute button from within the SW and the light came on.
  9. #9
    ROG Enthusiast SMiThaYe +10
    May 2012
    Location
    UK
    25
    I prefer to hear sound as it was intended too.
    What is the optimal sampling for most games on the Phoebus? I use 48KHz/24-bit for AAA+ titles (Batman series, BF3, CIV5, Mass Effect series), but unsure what exactly these titles are recorded at. Thanks.
    Intel Core i7-2600K @4.6GHz custom-H20 | Asus P8P67-Deluxe Rev. 03 | Asus ROG Xonar Phoebus | POV-TGT GTX680-SLI U.C. | Corsair GT 2x120GB (RAID0) | Corsair Vengeance 4x4GB @1866MHz | Corsair HX850 | HDD1: WD C.B. 2TB (games/programs); HDD2: WD C.B. 2TB (Fraps) | Win7 Home Premium x64 SP1
  10. #10
    Apr 2012
    35
    Would it be possible to add a box to "Play at original sampling rate". Is it possible for the driver to detect what the original sampling rate and bit depth was and just use that?
+ Reply to Thread
