I have a question or a request if someone could possibly explain the temp readings of the mianboard and the readings from the CPU? My temps that the MB reads is 38 while the the cores are much lower 17 I don't understand how you get 38 when I have 8 cores running at 17. I've got a screen capture of HWMP so you can see what I'm confused about. Also are my temps within range for this setup:
Antec 1200
Crosshair V Formula
FX 8120
GSkill 2133 16GB kit
Corsair 850 PS
XFX HD 6870 D Stack
120GB Pyro SSD
1TB WD
Thank you for your help
