02-02-2011 10:34 AM - last edited on 03-05-2024 07:39 PM by ROGBot
02-02-2011 11:10 AM
06-02-2011 07:34 PM
MarkS wrote:
On the JH model it's a half-height mini card and very easy to replace, and I'm assuming the JW is the same. Pop off your access panel on the bottom and you'll see. Two screws for the access panel, pop the two antenna wires off the card, two screws release the card which pops up at a 45 degree angle for removal. Installation is reverse of removal.
The Intel Centrino Advanced-N 6200 is a popular replacement...dual band, two antenna wires, 300Mbps capable, etc. There's also the Intel 6300 which I believe is 450Mbps capable but has posts for three antennas - some people have installed a third antenna while others have used the card with just the existing two antennas. Your mileage may vary...
I have the Intel 6200 and it works great paired with a Linksys WRT610N router.
06-02-2011 07:58 PM
mf051404 wrote:
I found a way to add a third antenna without disassembling the unit...it takes a bit of time to make it though (but good thing is..you don't have to disassemble the unit)...I will post photos later for reference...
06-03-2011 08:44 AM
06-03-2011 02:02 AM
06-08-2011 04:28 AM
mf051404 wrote:
Works well I suppose...improved reception with my old router...on the same location I used to get only around 70% (using system monitor gadget) with the old wifi card, got 90% with two antenna, and now 99% with three...maybe not so scientific. I will still have to test it though with the Linksys E4200 (I think this is the only one that supports up to 450MBPS) for the transmission speed, but I believe the antenna itself is working. My new router will be arriving soon. Could you suggest how to benchmark and what tool to use?
06-08-2011 07:20 PM
Chastity wrote:
I don't suppose you can make me one? 🙂
