CPU_FAN is best for cpu cooling fans, it allows the best range of operating conditions and is configurable.
CPU_OPT is only a 12v fan header, no configuration can be done (i.e. slow down the fan connected to it).
Don't use the 3rd header that is not labeled.... >>>>
http://rog.asus.com/forum/showthread.php?14692-What-is-the-3-pin-header-to-the-right-of-the-CPU-and-...
Intel Core i7 -2700K 4600MHz | Maximus V Gene | BIOS 0810 | 16Gb Corsair Vengeance LP @1600Mhz
Gainward GeForce GTX 570 Phantom @Clock 750Mhz Shade 1500Mhz Mem 975Mhz 296.10 drivers
24in ViewSonic VX2453 Series 1080p HD @1920 x 1080 60Hz
2 x 120Gb OCZ-VERTEX3 ATA Device (SATA-III) | 1 x 1TB ST1000DM003 ATA Device (SATA-III) | Corsair 750 AX
Corsair H100 4 x 120mm Noctua NF-F12 PWM (2 Push/2 Pull) | Xigmatek Gigas Black Case
