+ Reply to Thread
Results 1 to 5 of 5
Thread: GOt my g73 2 hours ago, battery question
    I would like to leave the battery out and packed away as ill never used it, my experiance from leaving the battery in has lead to them slowly dying will this also kill my battery leaving it out?
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,747
    No, batteries are rated based on charge/discharge cycles. If you do not use it then it should remain in the same condition.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    ROG Guru: White Belt MarkS +10
    Nov 2010
    Location
    California, USA
    107
    The batteries will still degrade over time even when removed (that's why you shouldn't buy spare batteries for the future).
    Drain it to around 40% charge and remove it. Put it in an airtight container/package and store in cool place (even refrigerator if you want). Check it periodically so it doesn't completely drain charge. That should maximize the life of the batteries.
    Jul 2010
    Location
    Sacramento, CA
    4,747
    True, nothing is forever, but it won't degrade as fast as it would if it were constantly charging/discharging.
    TeamROG Notebook Moderator Chastity@ASUS +10 Chastity@ASUS's Avatar
    Oct 2010
    Location
    California
    1,338
    Been using it since April, wear at 4%, battery always attached.
+ Reply to Thread
Similar Threads
  1. G73JH - Right fan cooling at 100% all the time, even on battery
    By tsfdeymos in forum Older G Series Notebooks
    Last Post: 05-24-2011, 04:51 AM
  2. G71GX-RX05 Battery Problem
    By Anonim0 in forum Older G Series Notebooks
    Last Post: 02-26-2011, 02:42 AM
  3. G73JW A1 Battery Mode/Graphics/FPS Issue
    By Optimo in forum Older G Series Notebooks
    Last Post: 02-14-2011, 05:17 AM
  4. R3E Question...
    By gvii in forum Rampage Series Motherboards
    Last Post: 11-01-2010, 09:01 PM
  5. ASUS Eee Pad official: Intel CULV processors, Windows 7, and a 10-hour battery life
    By Brian@ASUS in forum General Hardware, Overclocking & Tweaking
    Last Post: 06-01-2010, 06:55 PM
