+ Reply to Thread
Results 1 to 9 of 9
Thread: Asus Maximus V Ai Suite II Problems
    New ROGer maximine +10
    Jun 2012
    Location
    Romania
    5
    Hello guys, can somebody Help me with this erros ? I have tryed install/reinstall this program..Also EPU keeps crashing on windows boot(is disabled in BIOS). I have attached a screen regarding the error...Ai Suite II is the lateste version instaled from Asus Mainbord page.I have managed to setup all the fun`s once after finishing instaling the AI Suite II, after that never can go inside it.
    Version AISuite_II_V10229_MA_V_G_XPWin7 is instaled.
    ROG Guru: Blue Belt 8 Pack +20 8 Pack's Avatar
    Nov 2011
    Location
    U.K
    884
    I had this.
    Uninstall the entire Suite.
    Install the latest Intel management driver, then reinstall the Aisuite.
    Intel 3930K 5.5ghz+, DDR2600 , 3570K ,3770K
    ASUS RIVE, MVG,MVF,MVE.MIVE,MIVG -EZ
    G.Skill RipjawZ,PI and Trident X
    ASUS 7970, GTX580,570,470,460 etc etc
    Antec HCP 1200w x 2 and Coolermaster 1200w
    http://www.hwbot.org/user/8_pack/
    The GB Bencher. http://www.team-greatbritain.com/team-gb-members/
    Proud to be an ASUS power user!!!
    Jun 2012
    Location
    Romania
    5
    Hello.Thanks for your sugestion but the problem is still there with reinstaling the IME..
    I have unninstaled the Ai Suite, also IME was there, unninstaled this to...Rebooted, cleaned the registryes, instaled IME (MEI_allOS_8.0.10.1464_PV_5M) and after AI Suite II..
    Nope, I cant even open AI Suite II.Sometimes I can go inside Turbo EVo, but in the fan section not, the same errors are there.
    Intel Core i5-3570K 4500MHz | Maximus V Gene | BIOS 0813 | 2x4Gb Corsair Vengeance @2133Mhz 9-11-9-24
    Asus GeForce GTX 570 DirectCU II @Clock 900Mhz/1025Mhz
    24in LG 2453V-PF 1080p HD @1920 x 1080 60Hz
    120Gb OCZ-VERTEX3 MaxIOPS | 1 x 2TB Samsung F4 | 1x500Gb Samsung Spinpoint F3| Thermalthake 1350W
    Prolimatech SuperMega 2 x 120mm Coolink Swif 120P | 2x Noctua NF-F12 PWM | Corsair Carbide 400R Black Case
    Jun 2012
    Location
    Romania
    5
    Updated from fan expert V1.00.13 to V 1.00.15 and everything`s fine...Please update also Maximus V Gene utilities to the latest version, I took from other MB newer versions.
    ROG Guru: Yellow Belt nadof1 +10 nadof1's Avatar
    May 2012
    Location
    Nuneaton
    138
    Maximus V Gene - 3570k@4.4 - Noctua NH C14 - GTX 670 DC2T
    Corsair Vengance 2x4Gb - 2xForce3 240Gb Raid 0 - Sugo SG01B F
    Cooler Master 850w silent pro - 2x Redwing 80mm PWM
    AIR COOLED BABY
    Jun 2012
    Location
    Romania
    5
    putrid roodyas
    The same problem is back also with version V15 at the end...I dont know anything what to do anymore..have tryed what 8pack told me, nothing...have updated the fan expert II to new version, problem is back...What should I try anymore ?
  7. #7
    Nov 2011
    Location
    U.K
    884
    Do you actually use Fan expert ?? If you dont, dont bother installing it at all.
    On a side topic those DIMMS you have are hynix based so should go 9-11-10- ae they stable with the timings you have here????
  8. #8
    Jun 2012
    Location
    Romania
    5
    Hello my friend...if I understood your question,memory is fully stable..The kit is Corsair Vengeance 1866, 1.5v.They run on M5G at 2133Mhz, 9-11-9-24 T1 with 1.63v..I have tryed also 2200Mhz, but not tested the stability.
    In other manner, the problem from fan expert II is a compatibility issue with the latest MSI Afterburner & KIS2012.When I have closed it, everything runs ok.I have to check out the autostart option of the Afterburner, in this case I can acces fan expert.After that I can open MSI
  9. #9
    Nov 2011
    Location
    U.K
    884
    Hmmmmmm typical a clash in software. One or the other running then I guess.
+ Reply to Thread
