+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: USB Transfer Speed
    B(TX)assist 4Strings +20 4Strings's Avatar
    Mar 2012
    Location
    CO, US
    190
    USB Transfer Speed
    I don't know if i Posted this in the right forum, but...
    For some reason my computer's USB transfer speeds are ABSURDLY slow. Like, 60 -120 KB/second slow... It took my PC 15 minutes to transfer 121 MB!
    My system specs are in my signature.
    Any help would be GREATLY appreciated.
    Thanks in advance,
    4Strings
    Case:SilverStone Fortress FT02 (Black, Window)
    Motherboard:Crosshair V Formula-Z
    CPU:AMD FX-8350 @4.1GHz
    CPU Cooler:Corsair H80i+2 Gentle Typhoons
    RAM:16GBKingston HyperX Beast 2,133MHz
    GPU:XFX Double-D R7950 Black Edition (915Mhz Core/1375MHz Memory)
    SSD:Samsung 840 250GB
    HDD:WD Caviar Black 1TB
    PSU:Corsair AX760i
    Monitor #1:22" ViewSonic VX2250wm 1920x1080
    Monitor #2:19" Dell S199WFP 900x1440 (Portrait Orientation)
    OS:Windows 8 Pro
    Mouse:Logitech G9x
    Keyboard:Logitech G710+
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,757
    What was connected to the USB port? If it was a proprietary device (such as a phone/pda rather than a thumb drive) it might be in serial mode which is limited to emulating the speed of old serial ports.
    Have you tried different ports such as front & rear header ports as well as trying different USB devices?
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    Mar 2012
    Location
    CO, US
    190
    Quote Originally Posted by xeromist View Post
    @xeromist
    I was trying to transfer 2 videos (totaling 121MB) on to a thumb drive (a Kingston 8GB DataTraveler 2.0). I tried to connect it to a different port and there was no difference. I also tried reformatting the 8GB Kingston, and to use a generic 1GB thumb drive without any improvements.
    PSU:Corsair AX760i
    OS:Windows 8 Pro
    Mouse:Logitech G9x
    ROG Guru: Platinum Belt Zka17 +100 Zka17 +100 Zka17's Avatar
    Mar 2012
    Location
    Mount Pleasant, SC, USA
    5,324
    You could check the USB settings in BIOS... chapter 4.4.7 "USB configuration", page 4-27 in the manual... specially the USB 2.0 Controller Mode (HiSpeed: 480MBPS vs FullSpeed: 12 MBPS)...
    Additionally, it worth to check if your antivirus software is scanning the USB device in the same time as you try to copy from/on it... I use to forget this one... (first scan it/disable scanning, then copy)
    Mar 2012
    Location
    CO, US
    190
    Quote Originally Posted by Zka17 View Post
    @Zka17
    Thanks for the info!
    Firstly, I'm pretty sure that my anti-virus isn't scanning the drive. I'm using the Symantec Endpoint Protection (Version 11) that I got from my Dad's job, and I don't think it scans connected devices. If you know a way to check if it does scan, please let me know how to adjust that setting.
    Secondly, I don't have a manual for my motherboard... :P I never received one from alienware when I bought this computer... :P Would I be able to find the manual on the Asus website???
    Thanks again,
    4Strings
    PSU:Corsair AX760i
    OS:Windows 8 Pro
    Mouse:Logitech G9x
    Mar 2012
    Location
    5,324
    Quote Originally Posted by 4Strings View Post
    I'm not familiar with this software... sorry, have no idea about it's settings... In those I used in my life (Norton and McAfee) was able to set up if I want to have the external drives scanned automatically - hence my idea for you.
    Regarding the mobo's manual, you can download it here: http://www.asus.com/Motherboards/AMD...luxe/#overview
    Go to the "Download" section and follow the instructions!
  7. #7
    Mar 2012
    Location
    CO, US
    190
    @Zka17
    THANKS! I'll try checking the BIOS!!!
    PSU:Corsair AX760i
    OS:Windows 8 Pro
    Mouse:Logitech G9x
  8. #8
    Mar 2012
    Location
    CO, US
    190
    UPDATE:
    I checked the BIOS. and the USB setting was on "Hi Speed" as opposed to "Full Speed". And yet I still get ~70 KB/second...
    PSU:Corsair AX760i
    OS:Windows 8 Pro
    Mouse:Logitech G9x
  9. #9
    Mar 2012
    Location
    5,324
    Do you have the latest drivers?
  10. #10
    Mar 2012
    Location
    CO, US
    190
    Windows drivers?
    PSU:Corsair AX760i
    OS:Windows 8 Pro
    Mouse:Logitech G9x
+ Reply to Thread
