+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Help! I flashed my BIOS and now can’t turn on my G73JH
    New ROGer Galactica +10
    Mar 2011
    Location
    Denmark
    5
    Exclamation Help! I flashed my BIOS and now can’t turn on my G73JH
    Hi
    I wanted to update my Vbios and had read that it was recommended to have 209 as BIOS. My BIOS was 206, so I downloaded the 209 from Asus support and used EasyFlash from the BIOS to update.
    After flashing the computer it turned off and now I can´t get it running. No power at all!
    What to do?
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,835
    Have you tried removing the battery and unplugging the power?
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    Mar 2011
    Location
    Denmark
    5
    Yes.
    The light bulb only flicks very short and no signs of power at all.
    Jul 2010
    Location
    Sacramento, CA
    4,835
    Probably a bad flash then. It's rare but it happens. Is it under warranty?
    ROG Member asusrog +10
    Feb 2011
    15
    I need help tooooo......I've just tried to update my bios from 209 to 213 using in bios Ez flash and a usb drive formatted to fat 32.
    in the process the laptop is bricked. it wouldn't post the bios at all.
    when i push the power button all the blue lights , light up. i.e power, twinturbo, display mode, stealth mode, num lock, caplock (lights only)... keyboards lights do not light up.... fans are powered on, hardrive dvd is also powered on.... charging light lights up... and that's it.....i've tried taking out the battery, resetting through pin hole... no avail. my G73 is bricked and out of warranty ... what should I do?
    Feb 2011
    15
    Is there any way to "crisis recovery" ?
  7. #7
    ROG Enthusiast Mark Dano +10
    Nov 2010
    43
    Throw that outside the window =D
  8. #8
    ROG Member Slithster +10 Slithster's Avatar
    Mar 2011
    Location
    Nebraska
    I am in the same boat. I sent it in for repair even though they said it wouldn't be covered under warranty. I have heard the horror stories about bricked machines, but having flashed hundreds of Asus mobos over the last 15 years, this is the first time I have actually witnessed it. Of course, it was my personal machine.
    Laptop
    Fully functioning G73JH-A1
    Bike
    2002 Ducati 998
  9. #9
    ROG Guru: Yellow Belt 69_Goat +10 69_Goat's Avatar
    Jul 2010
    Location
    Alberta, Canada
    145
    If I'm not mistaken, Easyflash in the bios is used to update the motherboard bios, not the vbios.
    To update the vbios, you need to use ATIFlash for ATI graphics cards, or NVFlash for Nvidia graphics cards.
    I looked through the tutorials posted in the forums, and didn't see any mention of Easyflash.
    i7-980X | EVGA 762 Classified | 6GB Dom GT 2000C7 | GTX580 SLI
    i7-2600K | Asus MIVE-Z68 | 4GB Dom GT 2000C8 | GTX580 Martix
    69_Goat's HWBOT Profile
  10. #10
    Mar 2011
    Location
    Denmark
    5
    Never got my machine to run myself. Did RMA it to ASUS and got it home today. Got a new MB and BIOS is now 211.
    Sounds like the fans is running at full speed now. Very noisy!
+ Reply to Thread
Similar Threads
  1. Can't seem to turn on keyboard backlight on G53
    By Lionel Leow in forum Older G Series Notebooks
    Last Post: 06-22-2011, 05:23 AM
  2. Disappointing repair turn-around time
    By Tony Kilburn in forum Older G Series Notebooks
    Last Post: 12-21-2010, 05:56 PM
