Help is not working keyboard backlight
Ierahmieli
Hello help to solve the problem. My ASUS g73JH-A1
climbed all the sites are not times changed ATK Bios 213 Vbios 93
please give a link to the driver disk asus g73Jh-a1 THS
11 REPLIES 11
dstrakele
Level 14
Does the keyboard backlight flash once during startup?
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
What reaction did not
dstrakele
Level 14
If your keyboard backlights fail to flash once on startup, it means you need to:
1) get the fixmykb.rar file and flash it to your BIOS as discussed in http://rog.asus.com/forum/showthread.php?2810-Cant-figure-out-the-KB-fix....&p=18125&viewfull=1#post... Unfortunately, the link to this file in the referenced post is bad. I'm hoping some G73JH user can supply a working link for you.
OR
2) reseat the electrical connection of the cable that supplies power to the keyboard backlight LEDS.
first option is not very clear but I ask nothing but then switched from happening
I think the original disc can be set to all drivers .... but no active Shortcuts to download
dstrakele
Level 14
I found a thread with a good link for fixmykb.rar: http://forum.notebookreview.com/asus-gaming-notebook-forum/513264-keyboard-light-fix-gary-key.html. It is the "New Link" posted by @scottdrmyers.
please give active on the installation CD with drivers asus g73JH-a1
Just tried it, not working for me, any other way out?
dstrakele
Level 14
If you haven't deleted it, all the files on the Drivers and Applications CD should be available in C:\eSupport\eDriver on your system.
Unfortunately, they will be of no help in resolving your keyboard backlight issue.
I have a disk drive has been formatted, and no original purchased from another
I want to try with the original disc could you help me
