Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 97
  1. #11
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    Location
    Mount Pleasant, SC, USA
    163
    7,967
    Double check all the power cables, if they're connected correctly! If yes, then...
    Well, I do think that you will have to get some thermal paste and take of the cooler from the CPU... you do need to reseat your CPU and check the socket pins during that procedure...
  2. #12
    ROG Enthusiast Array
    Jul 2012
    65
    Okay now I got to booting errors d7 ( this is progress )
  3. #13
    Mar 2012
    Location
    163
    7,967
    D7 - no console input devices are found... well, not sure what's going on there...
    If I would be you, I would take it completely apart, then try reseating every component, attaching every power cable - also doing the CPU reseat as I said before...
  4. #14
    Jul 2012
    65
    I get error D7 now.... and my bios update failed for some reason ..
    Thank you so much for the help BTW
  5. #15
    Mar 2012
    Location
    163
    7,967
    Quote Originally Posted by Fax2u View Post
    I would not do BIOS updates until I'm not sure that everything else is fine... I mean, if you have a seeing issue somewhere, it's likely will have problems with with the BIOS update too...
  6. #16
    Jul 2012
    65
    Well I got to the Bios and It wont start. It says that The file is corrupted error "AE"
  7. #17
    Jul 2012
    65
    Now I cant see the bios and it says to recover bios settings... How do I do that?
  8. #18
    Mar 2012
    Location
    163
    7,967
    Fortunately, your mobo games with dual BIOS - on the right-down corner own the board, you can find the BIOS switch... hopefully that is still OK...
    Did you follow Raja's guide with the BIOS flashing? http://rog.asus.com/forum/showthread...untry=&status=
  9. #19
    Dec 2011
    Location
    London
    256
    25,205
    Please do the following.
    Clear CMOS
    Remove all your attached hardware from your system.
    All that should be left is your CPU and the cooler, nothing else.
    Now install the following.
    All you want is a VGA, keyboard and mouse.
    One stick of ram in the furtherest slot from the CPU
    Nothing else.
    After you have cleared CMOS again power up and select F1 when asked.
    Please post back when you get to that point.
  10. #20
    Jul 2012
    65
    I got to the bios and there's no HDD or optical drive connected or 16 gigx of ram now there's only 4
    So now what?
Tags for this Thread
