Results 1 to 6 of 6
    New ROGer Array
    Jul 2012
    3
    Asus G53SW hook up to a monitor
    Hi dear forumers,
    I would like to get an advice with regards to me hooking up my laptop to a monitor. isit advisable to do so? and isit advisable also to hook up to a dual monintor set up since it has a VGA and a HDMI port? Hope to hear from you guys soon!
    Thanks!
    Super Moderator Array Zygomorphic's Avatar
    Mar 2012
    Location
    In the Orion arm of a spiral galaxy in the Local Group...
    176
    4,761
    It has no problems running two monitors, the GTX 460M is a powerful card. The port you hook it up to depends on the inputs on your monitor. If it has HDMI, the hook it up that way, since that is an all-digital connection and the quality is higher. Otherwise, use the VGA port. Windows will recognize the second monitor and let you control it from Desktop Settings.
    New ROGer Array
    Jul 2012
    3
    Quote Originally Posted by Zygomorphic View Post
    Thanks for the reply. Isit possible to use 2 external monitors instead?
    Mar 2012
    Location
    176
    4,761
    Yes it should be, you hook up the two monitors to the VGA and HDMI ports, and then set the Windows settings to do nothing when you close the lid. That way, the lid can be shut without turning off the computer. Go ahead and try it, nothing bad will happen--barring aliens zapping your computer.
    New ROGer Array
    Jul 2012
    3
    Thanks for the answer Zygomorphic. I was just worried that my laptop could overheat or something. hehe. appreciate your help!
    Mar 2012
    Location
    176
    4,761
    Always glad to help. Driving two displays simply runs the video card at full speed...nothing to worry about in the G53. If you really worry, just leave the notebook lid open...probably a good idea. The G53 gets its air supply through the speaker grille, which would be covered when the lid is closed.
Tags for this Thread
