Results 1 to 6 of 6
    ROG Member Array
    Aug 2012
    Location
    Tokyo, Japan.
    SSD, Harddrives and RAID?
    So I was thinking about RAID and I did study a little about personal computers but I don't remember this very well and many online sources have some confusing information about this...
    2x Crucial m4 256GB (SSD) (X, Y)
    2x Western Digital Green 2TB (HDD) (Z, V)
    Now, I've heard about different RAID modes and was wondering what is the suggested for these? (In the same build)
    Also, how do I change the RAID on them?
    X will run my OS
    Y will run my Games + Adobe Suite
    Z will run Entertainment
    V will run Other Applications
    If this isn't a suggested way to set up what to have in the HDD/SSD please tell me what's a better way to do
    ROG Field / ROG Boson Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Malena Costa...yes way!)
    MotherboardRampage V Extreme 3.1 / GA X99-SOC Champion
    Processori7 5960X @ stock day-to-day / 4.4GHz/4.4GHz cache Gaming / 5.1GHz/4.7GHz cache OC
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2GTX Titan X
    Graphics Card #3Not yet...
    Graphics Card #4At these prices?...Not likely :-(
    Sound CardXonar Essence STX
    MonitorDell U2711
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Monsta 480s, EK Supremacy Evo, Dual EK TitanX WaterBlocks
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse Speedy Gonzalez
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker
    OS Win XP, 7, 8, 8.1, 10
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    Location
    In the gutter but looking at the stars
    351
    10,381
    Most common RAID setups take two drives and either, makes one drive out of the two with double the size of one disk.....Raid 0 or makes an exact copy of one drive on the other RAID 1 (there are other RAIDs)
    If you wanted to RAID two SSDs x and y they would not be independant you would have to use the one RAID array for OS and Games Adobe etc. At the same time you set this SSD raid up you could set up the HDD raid and put storage on that.
    http://rog.asus.com/77402012/rampage...d-setup-guide/
    ROG Enthusiast Array Radiant mind's Avatar
    Feb 2012
    17
    67
    The simplest setup would be this:
    2x SSDS in RAID 0 for pure speed (this will give you ONE logical drive in the OS @ 512GB) Store your OS, Games on this drive
    You have 2 options for the other drives, but I would recommend RAID1 since you will already have a RAID0 with SSDs for performance: (Store large files, media, programs that dont need fast read/writes on this array).
    2x 2TB in RAID 1 for mirroring. You will still only see one logical drive in the OS, and you will only be able to utilize 2TB, not all 4 since they are mirroring.
    2x 2TB in RAID 0 for speed giving you a total a 4TB logical drive in the OS.
    Always remember:
    RAID0 will give you faster speed and more capacity, BUT IS NOT FAULT tolerant. If you lose a drive, you're screwed and have to rebuild.
    RAID1 will give you more redundancy and less capacity, it is fault tolerant, as in if you lose one drive, you can still retrieve your data.
    i7-3820 @ 5.0Ghz - RIVF - 32GB Kingston @1866 - Gigabyte Radeon 7970 x2 - Cosair Force GT 240GB x2 (RAID 0) - WD 2TB 7200 (RAID 1)
    Dec 2011
    Location
    London
    256
    25,205
    RAID 0 is so tempting for the OS - I have done so as have many many others. And I hope unlike many others (but this I doubt) I have had a hard drive go down on me. And I lost all my work, two weeks between back ups and that meant a whole heap of time and effort went down the toilet. Nett result is that I am not a fan of a stripped array. (RAID 0) The gains in speed are so marginal in the real world when you go SSD any way that I do not see the point any longer.
    But hey I am very grey in the beard and like to keep my work where I can access it, you go for the speed option if you are willing to take the risk.
    Feb 2012
    17
    67
    RAID 0 is just luck in general. If you're going to do it, don't put anything that you can't absolutely lose. I have noticed pretty decent gains in speeds with RAID 0 on SSDs, but its nothing mind blowing. (Plus you lose the TRIM feature)
    I only mention RAID 0 because he actually has 2 SSDs, having two is a waste for RAID1 for the cost of SSDs. I supposed he could just have a JBOD between the two.
    Another option, although expensive, would be RAID5 for 3xSSDs. Gain a little bit best of both worlds: Speed + Redundancy.
    MonitorDell U2711
    Apr 2012
    Location
    351
    10,381
    RAID 0 for SSDs is great for benchmarks but not noticable in everyday performance. If you go for it you need aggressive garbage collection from your controller and need to allow that to run in order to make up for the loss of TRIM. If you do lots of writes you will soon see a drop in performance without TRIM.
    Future driver releases are supposed to bring TRIM to RAID SSD I'll wait for that. At the moment RSTe drivers are slowing performance compared to Microsoft AHCI!
Tags for this Thread
