This is true. Just for giggles I once tried 360mm worth of rad for a CPU and 3 8800GTX's and they were still hot so that is just waaaay short on rad surface for that build.
Thanks guys for all the help! Yeah the 240mm rad isnt enough to cool all the components. Im probably gonna add a few more radiators to try to bring the temps down. Thanks again
If you thing that your case's size is a problem for more radiators, you may consider external radiators too... attached to your system by quick disconnects...
My wife's computer I built has the same case. It's a bit cramped for a proper water setup. Without changing a whole lot I would put a couple of powerful scyths blowing in fresh air to the radiator. It'll sound loud, but your temps will improve.
