what the best wifi card for g75
Sunrise2000
Hi, I have intel wireless n 105 which is very slow, and I cant stream media files online. I found that the G75 also supported these models:
CENTRINO WIRELESS-N 2230
AZWAVE/AW-NB097H
AZWAVE/AW-NE186H
Which models is the best? I need 2x2 antennas, 2.4 and 5 ghz and 300 mbps.
I want to install Intel® Centrino® Advanced-N 6200, but I dont know if support
soulctcher
I have installed an Intel 6235, which has been working great since. I would suggest that if you install it, you do a complete reinstall of windows and all the drivers since the bluetooth stack will likely need to be rebuilt and it's a pain if you don't reinstall windows.
thanks for answer. Maybe enyone have a intel 2230 adapter? What about this adapter, he is fast, slow?
does g75 support Bigfoot networks Killer™ Wireless-N 1102 ? Have anyone? How much antennas this model have?
