+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: USER GUIDE:Maximus IV Extreme + 8GB GSkill Flare BIOS setting guide for DDR3-2133
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,798
    Just a quick post for anyone that has this kit and is looking for overclocked settings. These should give you a starting point. No guarantees these will work on every CPU and memory as no two processors or memory modules are exactly the same.
    Test Components
    Maximus IV Extreme - BIOS 1485
    Corsair AX1200 PSU
    OCZ 120GB Vertex SSD
    GSkill Flare 8GB f3-16000CL8D-8GBFLS Memory Kit
    Noctua NH-U12P CPU Cooler + 2x120MM fans (push-pull)
    You may ignore my CPU overclock settings and choose to substitute your own as parts and cooling allow
    BIOS Settings:
    tRRD, tRTP, tWTR are all set as tight as DDR3 timing constraints allow at the chipset level.
    tRAS can go one clock tighter to 23 if desired (minimum tRAS is tRCD+CAS+tRTP), though some modules might need a touch more VDIMM.
    I have set BCLK skew to +100 as it helps with stability on my CPU - you may wish to experiment with this.
    Stability screenshots
    Any questions, feel free to ask.
    -Raja
    ROG Enthusiast MIVE +10
    Jul 2011
    Location
    Melbourne
    48
    G skills ram is more compatible than corsair for this motherboard?
    Apr 2011
    Location
    ASUS North America
    2,798
    No, it depends on the IC more than the vendor.
    Jul 2011
    Location
    Melbourne
    48
    ok. because i got Corsair Vengeance CMZ8GX3M2A1600C8 8GB (2x4GB) DDR3 and my system keeps on freezing. i don't know what's wrong with it
    Apr 2011
    Location
    ASUS North America
    2,798
    Update to BIOS 1850 and see if that helps. If it does not, let me know. Be sure to provide all your system info - all parts used, drivers and configuration.
    Raja
    ROG Enthusiast Rammstein874 +10
    Jun 2011
    Location
    USA
    32
    @ Raja@ASUS will this work with my system?
    Systemboard: ASUS MAXIMUS IV EXTREME (REV 3.0) LGA 1155 Intel P67
    CPU: Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost)
    CPU Cooling: CORSAIR Hydro H70 CWCH70 120mm High Performance CPU Cooler
    PSU: Rosewill LIGHTNING Series LIGHTNING-1000 1000W ATX12V/EPS12V
    SSD: OCZ Vertex 2 OCZSSD2-2VTXE60G 2.5" 60GB SATA II MLC
    Video Card: EVGA SuperClocked GeForce GTX 580
    Ram: CORSAIR DOMINATOR GT 8GB 240-Pin DDR3 SDRAM DDR3 2000
    Case: IN WIN Dragon Rider Black
    Other: CORSAIR AirFlow Pro
  7. #7
    Apr 2011
    Location
    ASUS North America
    2,798
    You mean the settings in the first post work with your memory? May need some adjustments to voltages and timings depending upon the capabilities of your memory kit and CPU. You can try I suppose.
    -Raja
  8. #8
    Jun 2011
    Location
    USA
    32
    Quote Originally Posted by Raja@ASUS View Post
    -Raja
    I will try it. If it does not work could you help me tweak it to make it work?
  9. #9
    Apr 2011
    Location
    ASUS North America
    2,798
    Sure, you will need to post up your settings and such if need be.
    -Raja
  10. #10
    ROG Enthusiast pectin232 +10
    Aug 2011
    Location
    Nashville
    26
    Raja this is mine I tried your settings but it freezed after a few days... not sure what else to do.. temps are ok. CPU is at 40 and Board is 41.
    ASUS Maximus IV Gene-Z LGA 1155 Intel Z68
    CPU: i7 2600k
    CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 CMZ8GX3M2A1866C9R
    LIAN LI PC-V354B Black Aluminum MicroATX Mini Tower
    Corsair 120SSD
    Western Digital Caviar Black WD1002FAEX 1TB
    SAMSUNG EcoGreen F4 HD204UI 2TB
    CORSAIR Professional Series HX850 (CMPSU-850HX)
+ Reply to Thread
Similar Threads
  1. Maximus IV Extreme Bios, Sandybridge CPU Overview, and CPU Overclocking Guide
    By Brian@ASUS in forum Maximus Series Motherboards
    Last Post: 02-13-2012, 01:54 PM
  2. How to Overclock ASUS RAMPAGE III Extreme BIOS GUIDE
    By V2-V3 in forum Rampage Series Motherboards
    Last Post: 10-13-2011, 12:57 AM
  3. ASUS Rampage III Extreme Overclocking BIOS Guide
    Last Post: 10-11-2011, 09:23 PM
  4. user default setting in Bios?
    By Lucciola in forum Older G Series Notebooks
    Last Post: 03-15-2011, 04:10 AM
  5. PLZ.,,.POST OVERCLOKING GUIDE FOR MAXIMUS III FORMULA.,.,
    By GRIDLOCK in forum Maximus Series Motherboards
    Last Post: 09-03-2010, 06:39 PM
