Results 1 to 6 of 6
    ROG Guru: Brown Belt Array GottiBoi55's Avatar
    Dec 2011
    Location
    Florida...USA
    22
    1,116
    Cool How to Calibrate your laptop smart battery.
    Hope this procedure will help you with keeping up your battery health.
    1. Plug the AC adapter into an electrical outlet and connect it to your laptop until battery is fully charged.
    2. Once the battery is 100% charged click Start button, and then click Control Panel.
    3. Click Power Options, and then create new power plan by clicking Create a power plan.
    4. Create new plan name such as Calibrate Battery, and then click Next.
    5. Select the Never On battery value for Turn off the display, and Put the computer to sleep and then click Create.
    (This will prevent your notebook from turning off the display and entering Sleep mode to drain battery faster.)
    6. Next unplug AC adapter.
    7. Select MP3 file with a bit rate of 128 kbps.
    8. Set WMP to repeat mode and start the MP3 file, and let the file run.
    (make sure volume is all the way down)
    9. Allow the battery to discharge completely until the laptop turns off.
    10. Plug in the AC adapter and restart your laptop, and charge battery fully.
    This procedure should be done once a month to keep battery health up.
    Good luck, and enjoy!
    Edit: thread name, should have been "smart battery calibration".
    Sorry for the confusion
    Last edited by GottiBoi55; 09-20-2012 at 02:45 AM. Reason: To make things little more clear.
    GottiBoi55
    Asus
    G750JZ-DS71 Windows 10 Pro (x64)
    Intel® Core™ i7 4700HQ (2.40GHz)
    Samsung
    24GB Memory DDR3 1600 MHz SDRAM
    SanDisk
    M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM
    NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM
    Second Monitor: Shar
    p Aquos 32"
    No Longer Works at ASUS Array
    Jul 2012
    68
    764
    Battery calibration is something of an anachronism. It really hasn't been necessary for a long time. All you really need to do these days is charge it when it's low, dispose of the battery when it fails, the end.
    And just so you don't mistake my meaning... Feel free to post things like this if you think there helpful, but if they happen to be part of the large quantities of outmoded "advice" floating around out there, someone may point it out. So, don't take it personally, just take it as an opportunity to learn something new.
    Super Moderator Array Zygomorphic's Avatar
    Mar 2012
    Location
    In the Orion arm of a spiral galaxy in the Local Group...
    176
    4,761
    It was necessary with the old "dumb" batteries and the nimh/nicads. Modern lithium batteries do smart charging, which eliminates the need for calibration.
    I am disturbed because I cannot break my system...found out there were others trying to cope! We have a support group on here, if your system will not break, please join!
    http://rog.asus.com/forum/group.php?groupid=16
    We now have 178 people whose systems will not break! Yippee!
    LINUX Users, we have a group!
    http://rog.asus.com/forum/group.php?groupid=23
    Dec 2011
    Location
    Florida...USA
    22
    1,116
    What is Smart Battery Calibration?
    Repeated short discharges and recharges cause increasing inaccuracy between the state-of-charge of the battery and the Power Meter readings. Periodically, the battery needs to be calibrated to "relearn" its usable capacity so it can synchronize its charge status with the Power Meter. The calibration procedure maximizes the notebook run time by giving the user an accurate estimate of the remaining battery charge. Calibration also prevents data loss that can occur during the Hibernation process if sufficient power is not available to complete critical save-to-disk operations.
    Smart Batteries calibrate their FCC each time they undergo a full discharge-charge cycle, whether they are recharged in the notebook or in a stand-alone charger/conditioner. Calibration using the notebook is less convenient because it can take up to 4 hours; however, it can lead to more relevant results than using a stand-alone charger.
    Calibration results using the notebook are more relevant because the battery relearns its FCC while undergoing a realistic power load. In a stand-alone charger, the battery is discharged using a fixed load. If the fixed load is less than the load typically experienced by the notebook, the learned capacity of the battery may be higher than its actual capacity. In other words, the newly calibrated battery may not deliver the run time predicted by the Power Meter if it is subjected to a greater load than the load used to calibrate the battery.
    The accuracy of today’s Smart Battery enables precise calibration when the battery is discharged to about 5% of its remaining capacity. Consequently, the user can set the battery alarm at 5% of remaining capacity so that the Smart Battery will calibrate its capacity during normal use.
    The user simply has to periodically discharge the battery until the 5% capacity alarm is received. The need to perform this procedure will vary with individual use. In general, a Li-Ion battery should be calibrated a minimum of once every 3 months. A battery that is seldom discharged completely should be calibrated about once a month.
    Hope this will make things little more clear on "smart battery calibration"
    GottiBoi55
    Asus
    Samsung
    SanDisk
    p Aquos 32"
    ROG Guru: Green Belt Array
    Jul 2012
    48
    691
    BatteryBar constantly monitors the status of your battery as you use your laptop. As it monitors your battery, it keeps historical data on your battery and provide you with a very accurate estimate of how much time is remaining on your battery.
    I just use this http://osirisdevelopment.com/BatteryBar/
    It does a good job on all the laptops so far.
    Dec 2011
    Location
    Florida...USA
    22
    1,116
    Quote Originally Posted by c_man View Post
    Thanks for your input, that looks like a sweet little battery meter app.
    GottiBoi55
    Asus
    Samsung
    SanDisk
    p Aquos 32"
