Reboot and select proper boot device? Help!
Epialos
Hey guys, I own an Asus G55. I was browsing my files and not really doing much until the laptop restarted on me. Afterwards it keeps saying Reboot and select proper boot device and it isn't loading the OS. How can I fix this without losing anything?
34 REPLIES 34
dstrakele
Level 14
Is your HDD in the boot device list?
Try this - Open the back, remove and reseat the connection to your HDD.
If that fails, insert a Windows install DVD or USB flash drive (you can make 'em if you don't have one) and attempt to repair your Windows installation.
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
I just tried what you said, but it's still giving the same problem..
restart your laptop, and once you see the "asus logo" hit the F2 button and enter BIOS.
Go to "Boot Tab", and make sure your OS drive is enabled to the first position.
then hit F10 and select save, and exit.
If that didn't work you can try a "Repair action" from a Win7 install disk.
this action should most likely work.
Good luck, and enjoy!
GottiBoi55
Asus
G750JZ-DS71 Windows 10 Pro (x64)
Intel® Core™ i7 4700HQ (2.40GHz)
Samsung
24GB Memory DDR3 1600 MHz SDRAM
SanDisk
M.2 SSD 2x128GB in Raid 0 / WD-HGST-1TB HDD 7500-RPM
NVIDIA® GeForce® GTX 880M 4 GB GDDR5 VRAM
Second Monitor: Shar
p Aquos 32"
I don't have a windows 7 install dvd. My internet is rather slow and downloading the ISO takes about 5 hours 😕
I tried the BIOS but the only option I had was the DVDRAM one.
Okay, start your laptop and enter BIOS again, in the last tab select "Load optimize defaults"
then select "save, and exit"
I hope that works for you.
GottiBoi55
Asus
Samsung
SanDisk
p Aquos 32"
My last tab in bios is "save and exit". I don't see the option load optimize defaults but I do have a restore defaults which I have already tried..
yes select that one "restore defaults" , sorry for the confusion.
GottiBoi55
Asus
Samsung
SanDisk
p Aquos 32"
yes , select that one "restore defaults", sorry for the confusion.
GottiBoi55
Asus
Samsung
SanDisk
p Aquos 32"
That didn't seem to work. It still only has dvdram.
& I asked a few friends, none of them have it. They're laptops came with windows 7 so I guess no one bothered getting the installation disc.. :mad:
